Top speed in each gear?
Its easy to figure out without getting to the top speed, at least until the speed is limited by drag in the upper gear (Porsche says the max speed is obtained in 6th). The ratio of RPM to speed is linear in each gear. So you could go half of the red line RPM and look at the speed then double it to get the top speed (or 1/3 and triple it etc..)
Here is what I saved for carrera and carrera S, manual and PDK.
I am not offhand sure where I got the redline, if it's not correct let me know.
carrera manual
outside diameter: 682mm (26.9 inch)
outside circumference: 2142mm
gear 1 rpm 1000 travel per second: 2.7 m/s 9.6 km/h 6.0 mph
gear 2 rpm 1000 travel per second: 4.5 m/s 16.3 km/h 10.2 mph
gear 3 rpm 1000 travel per second: 6.7 m/s 24.1 km/h 15.1 mph
gear 4 rpm 1000 travel per second: 8.0 m/s 28.8 km/h 18.0 mph
gear 5 rpm 1000 travel per second: 9.6 m/s 34.6 km/h 21.6 mph
gear 6 rpm 1000 travel per second: 11.8 m/s 42.5 km/h 26.5 mph
gear 7 rpm 1000 travel per second: 14.6 m/s 52.6 km/h 32.9 mph
gear 1 rpm 7800 travel per second: 20.7 m/s 74.6 km/h 46.6 mph
gear 2 rpm 7800 travel per second: 35.4 m/s 127.3 km/h 79.6 mph
gear 3 rpm 7800 travel per second: 52.2 m/s 188.1 km/h 117.6 mph
gear 4 rpm 7800 travel per second: 62.3 m/s 224.3 km/h 140.2 mph
gear 5 rpm 7800 travel per second: 75.0 m/s 269.9 km/h 168.7 mph
gear 6 rpm 7800 travel per second: 92.0 m/s 331.3 km/h 207.1 mph
gear 7 rpm 7800 travel per second: 114.1 m/s 410.6 km/h 256.6 mph
carrera s manual
outside diameter: 685mm (27.0 inch)
outside circumference: 2151mm
gear 2 rpm 1000 travel per second: 4.6 m/s 16.4 km/h 10.2 mph
gear 3 rpm 1000 travel per second: 6.7 m/s 24.2 km/h 15.1 mph
gear 4 rpm 1000 travel per second: 8.0 m/s 28.9 km/h 18.0 mph
gear 5 rpm 1000 travel per second: 9.7 m/s 34.8 km/h 21.7 mph
gear 6 rpm 1000 travel per second: 11.8 m/s 42.7 km/h 26.7 mph
gear 7 rpm 1000 travel per second: 14.7 m/s 52.9 km/h 33.0 mph
gear 1 rpm 7800 travel per second: 20.8 m/s 74.9 km/h 46.8 mph
gear 2 rpm 7800 travel per second: 35.5 m/s 127.8 km/h 79.9 mph
gear 3 rpm 7800 travel per second: 52.5 m/s 188.9 km/h 118.1 mph
gear 4 rpm 7800 travel per second: 62.6 m/s 225.2 km/h 140.8 mph
gear 5 rpm 7800 travel per second: 75.3 m/s 271.1 km/h 169.4 mph
gear 6 rpm 7800 travel per second: 92.4 m/s 332.7 km/h 207.9 mph
gear 7 rpm 7800 travel per second: 114.5 m/s 412.4 km/h 257.7 mph
carrera pdk
gear 3 rpm 1000 travel per second: 6.3 m/s 22.7 km/h 14.2 mph
gear 5 rpm 1000 travel per second: 10.4 m/s 37.4 km/h 23.4 mph
gear 7 rpm 1000 travel per second: 16.7 m/s 60.3 km/h 37.7 mph
gear 3 rpm 7800 travel per second: 49.1 m/s 176.7 km/h 110.4 mph
gear 5 rpm 7800 travel per second: 81.0 m/s 291.5 km/h 182.2 mph
gear 7 rpm 7800 travel per second: 130.6 m/s 470.2 km/h 293.9 mph
carrera s pdk
gear 5 rpm 1000 travel per second: 10.4 m/s 37.5 km/h 23.5 mph
gear 7 rpm 1000 travel per second: 16.8 m/s 60.5 km/h 37.8 mph
gear 3 rpm 7800 travel per second: 49.3 m/s 177.4 km/h 110.9 mph
gear 5 rpm 7800 travel per second: 81.3 m/s 292.8 km/h 183.0 mph
gear 7 rpm 7800 travel per second: 131.2 m/s 472.2 km/h 295.1 mph
carrera manual
carrera s manual
carrera pdk
carrera s pdk
I tried to calculate the top speed of two vehicles (991.1 X51 and 992.2 3.0 Turbo S) where I balance off engine power versus aerodynamic drag and rolling losses. When the acceleration is 0 m/s in the graph there is no more power to accelerate any faster so that is the theoretical maximum speed in that gear.
https://rennlist.com/forums/991/8932...l#post12592622
My top speed in 6th gear appears close to Porsche's published numbers (within 1 km/hr for both) but the low maximum speed in 7th gear for the 991.1 X51 seems suspect.
