Chirp or beep on lock
#31
The dealer can definitely activate it, it's a setting in PIWIS. Now... will the dealer actually do it? Hard to say. My 2013 with entry and drive didn't chirp until I installed a smarttop module (I have a cab). For some reason, it started chirping after that.
#32
Many of the cases of 'intermittent' chirping are solved with replacing the module that makes the chirping.
#34
No, you don't have a problem. The dealer can activate beep/chirp and/or lights flash if you want it. The problem is the dealer may want to charge you to do it.
