Under Glove Compartment Pollen Cabin Filter
Old 06-20-2015, 06:24 PM
cdelrosario
cdelrosario's Avatar
Default Under Glove Compartment Pollen Cabin Filter
Hi All,
Just a quick post on finding the 2nd, bigger cabin filter for our 991's. Searched high and low and couldn't find a definitive post so here's mine.
It's a 10 minute job. First, glove box removal is NOT necessary. If you stoop and look under the glove box, there is a foam cover held on by 3 plastic screws. You only need remove the screws and foam cover and the door of the Cabin Pollen filter is now accessible. Open door, pull out filter and replace! Voila!
Old 06-20-2015, 06:27 PM
cdelrosario
Bigger Pollen Filter
Old 06-20-2015, 06:30 PM
cdelrosario
foam cover held on with plastic screws
Old 06-20-2015, 06:34 PM
cdelrosario
Here's the Door with the Foam over peeled back...I only removed the two screws and was able to access.
Old 06-20-2015, 07:13 PM
Duke I
Duke I's Avatar
Nice!! Good find and thanks for sharing.
Old 06-20-2015, 07:53 PM
Vic and Ray
Vic and Ray's Avatar
Don't forget about the second air filter in the frunk which is even easier to replace...
Old 06-20-2015, 08:06 PM
dr.alexs
dr.alexs's Avatar
How often is it recommended to change these out? Do they get changed during the standard service? Should we be doing this in addition to the standard service intervals?
Old 06-20-2015, 08:17 PM
roadrat
roadrat's Avatar
Nice work. Thanks for sharing!
Old 06-20-2015, 08:35 PM
cdelrosario
I have 17,000 miles & changed both filters. Yes, the smaller Frunk filter was a piece of cake & the filter actually came with a pictoral on how to change. The bigger filter had zero. I only knew it was somewhere near glove box.
The bigger filter was not nearly as dirty as the frunk smaller filter. I plan on changing every year, a small cost for clean cabin air.
Old 06-20-2015, 09:20 PM
Duke I
Duke I's Avatar
Where did you source the filters?
Old 06-20-2015, 09:48 PM
SDaddy
SDaddy's Avatar
Porsche has published a service booklet with details...
File Type: pdf
Old 06-20-2015, 10:22 PM
cdelrosario
I went thru Pelican Parts...The pollen filter was"Micron" brand and when compared to the original...looked eerily similar at 1\4 the price.
Old 06-21-2015, 12:56 AM
Powereng
Powereng's Avatar
Thanks for posting
Old 06-21-2015, 01:31 AM
dr.alexs
dr.alexs's Avatar
Nice...thanks!!
Old 06-21-2015, 02:13 AM
Bigalfromfl
Bigalfromfl's Avatar
Very nice info and pics. Thank you for posting!
Quick Reply: Under Glove Compartment Pollen Cabin Filter
