PCM Software Version Update
Old 12-18-2015, 05:48 PM
  #46
Pavegeno928
Pavegeno928's Avatar
Soon:
"From 2016, Porsche Tequipment will offer a retrofit solution for vehicles fitted with PCM 3.1 and built after November 2012. If the “online services” option is already installed, the update will cost €232.05 (inc VAT).
For PCM 3.1s without “online services”, the retrofit will cost €351.05 (inc VAT) and will include the latest map data. To discuss your options, contact your local Porsche Centre."
From: http://www.total911.com/real-time-tr...ew-pcm-system/
Old 02-24-2016, 12:20 PM
  #47
Pavegeno928
Recently got 4.76 and iPhone seems more stable...
Old 06-04-2016, 09:41 PM
  #48
bright_medal
bright_medal's Avatar
Originally Posted by Arcoril
I've got a 2012.5 that's currently running 3.43. I understand that 2013 got a slight PCM refresh with support for online services and runs the 4.x branch of code. Has anyone had any luck getting their 2012.5 updated with 4.x? Or are we stuck on 3.x?
I wanted to resurface this question. I bought a 2012.5 C2S and have v3.43 software. Has anyone been able to update past v3? Thanks!
Old 06-04-2016, 11:38 PM
  #49
Happy911S
Happy911S's Avatar
I have version 4.76 which my dealer loaded under warranty because I was having issues with the it resetting. I think if you tell the dealer that the system just resets itself they will update under warranty.
Old 06-05-2016, 09:38 AM
  #50
Jabs1542
Jabs1542's Avatar
I also have a 2013 and am at 4.76.
Old 06-05-2016, 05:30 PM
  #51
mdrobc1213
mdrobc1213's Avatar
Originally Posted by jsaviano
My local dealer discouraged me from the backup camera installation. Lots on work including partial dismantling of the interior. Apparently it's not prewired or anything, unless it was ordered when the car was built. I'm not doing it.
I'd check with another dealer. Mine referred me to a shop who did the whole job in a day for a cost of A$1200 installed using the NAVTV module. Works perfectly without issues. Costs more than if car was ordered with it....but since it was CPO'd wasn't an option.
Having car in for PSE wiring and AWE exhaust install later this month. Will have to ask about having this done at that time too. Assume they will since they'll have to updated the software to add the PSE anyway one would guess.
Old 07-07-2016, 04:48 PM
  #52
BradB
BradB's Avatar
4.76 here, too.
Old 11-18-2016, 03:45 PM
  #53
Pavegeno928
4.76 for nine months now and not a single PCM/map issue. Thoroughly enjoying the PCM and map functions. Been all over Europe and it hasn't let me down. I run Waze in parallel and find Waze to be a little better than the Real-Time traffic through the Online Services Option powered by INRIX over here. The google POI search is far better than PCM database and I use it almost exclusively.
When I did the Online Services and Euro Map Update, the map license key is PCM 3.1 Europe 8/2015. My car is a US Spec built in March 2014. I'm assuming there was a US Map Update around the same time. I'll be returning to the US next summer and figure I'll need a US Map update. Anyone know the latest map version and the cost?
Old 03-11-2017, 03:57 PM
  #54
sonnenschein3000
5th Gear
sonnenschein3000's Avatar
Does the dealer have to remove the PCM system from the dashboard to do this, or can it be done via the OBD port?
Old 03-11-2017, 04:03 PM
  #55
Vise
Vise's Avatar
Definitely does not require the PCM to be removed, it is likely updated via USB but not positive.
Old 06-29-2017, 12:10 PM
  #56
Fünfer
Fünfer's Avatar
Mine is on V4.76 right now.
Is that still the latest version, for 991.1 with PCM3.1?
Old 11-25-2017, 08:10 AM
  #57
Pavegeno928
Had a bit of a setback. Had been running 4.76 for quite a while. Just before departing Stuttgart back in June 2017 after three years, I had the dealer load the latest USA maps. It dropped my SWV to 4.52. I didn't notice it until I got back to the good old USA. I've brought the car to the dealer locally, and they can't seem to figure it out. Anyone have definitive information on how to get it back to 4.76 and confirm the latest USA maps?
Old 11-28-2017, 08:43 PM
  #58
Pavegeno928
Confirmed with Suncoast today that 4.76 is the latest and the USA Maps I have are the most current. They suggested getting Service Campaign WF27 reloaded to clear up a BT issue and that should bring me back to 4.76. Will be at the dealer in Montgomery again in a few weeks and will see if that does the trick.
Old 02-11-2018, 09:22 AM
  #59
Pavegeno928
Deler in Montgomery was unable to get me back to 4.76. They reloaded the USA Maps 997-044-908-61 and it still said 4.52.
Anyone crack the code on how to get a SWV updated to 4.76?
Old 02-11-2018, 06:45 PM
  #60
gellie
gellie's Avatar
Do the new 991.2’s have automatic updates or do you still need to bring it to the dealer?
Quick Reply: PCM Software Version Update
