Roof Liner Rattle
Roof Liner Rattle
Hi have a small rattle in my roof liner. It is exactly where the liner meets the rear passenger window. If I push it while driving the rattle stops. Would stuffing felt inside do the trick or by the edge where it meets the widow? Also I have no idea how much give the liner has to pull down a little ,to try to stuff some type of buffer(what could I stuff in there) that could quiet the rattle....Any help would be appreciated!!!
I had a rattle in the exact same place. I cut off a piece of cheap rubber floormat from walmart and stuffed it back there. The piece was about 1 inch by 3 inches and I think I folded it to create some tension. 991's have all sorts of rattles back there. I took out the rear seats and seatbacks and now I am rattle free.
I tried to put a little felt between the liner and the window and did not solve the problem. Any thoughts on what I could stuff inside the liner to keep it from rattling. Obviously it is not rattling against the window. I need to stuff(any ideas) inside the liner to stop moving. Thanks again for being a newbie.....!
I would just have the dealer fix it because further yanking on the roof liner may snap an attachment point and lead to sagging due to gravity
I don't envy you, I had the same issues. Drove me crazy. At times I felt like I was the only person that noticed as others who road with me thought I was crazy.
Took multiple trips to the dealer to get it resolved (not sure how, probably with tape of some sort). I'm thankful those days are over.
ideally you show demonstrate that sound when you take it in .....also ask the service writer to assign the job to their best " noise guy " , as it seems that a life of working in a noisy environment causes the majority of the wrenches to " lose " their hearing for the rattle/squeak sounds that drive owners crazy
Picking up the car this afternoon.Service advisor said the tech stuffed some foam up in the roof liner...They both went for a test drive and said it is ratlle free. Keeping my fingers crossed!
good luck!
Sorry I was not clear...If I pushed the liner right above the rear window the rattling would stop. Thats why I am hoping that sticking the foam inside the liner will do the trick.
