Auxiliary Blue tooth streaming
I have a Iphone 6 and usually when driving I can push the Aux button and the Blue tooth signal is on top of it which allows me to play my music from my iPhone via Bluetooth streaming. Now it is not working and I tried to re pair the phone. Any ideas on how to get that back. It was great! Thanks in advance for your help!
You may want to check to make sure AUX BT is still enabled in the PCM. Select one of the sources available with the "Media" button, then go to the "Option" tab. Tap "Set Media/Aux" and then verify the "AUX Bluetooth" source is checked/enabled. Hopefully that helps if the prior suggestions didn't do the trick!
mine did the same thing when i updated to ios 8.2, seems to happen more frequently with all the 8.xx apple updates it has had to send out because of bugs.
power down reset of phone when i got home. next day was back to working (until 8.2.1 comes out probably)
Are you able to stream Pandora, etc. with the phone plugged in? If so, I must be doing something wrong, because as soon as I plug in the streaming stops and I have to re-establish the BT connection. Thanks.
I dug out an older iPhone I had in a drawer and repurposed it as a dedicated iPod in the car. It's just permanently plugged in and sits in the glovebox. I take it out to resync it with iTunes when I come up with new music or a new playlist.
H.
H.
Hi,
I'm coming over from the GT3 forum and quite a few of over there are having volume issues -- meaning FM radio volume is MUCH louder than BT volume, and when the car starts up, the default audio is FM so after shutting down from BT the volume is way to loud.
Most have just addressed this by adjusting the volume on their phones to max.
Any other ideas?
thanks,
Kevin
Any other ideas?
thanks,
Kevin
