Oh no! Not again...
Playing dumb is the best move.
If it will get fixed under the existing open claim, just let it be.
Let the body shop deal with the insurance, they know the game best.
Just make sure body shop is reputable and not the type that cuts corners.
Last thing you want is insuramce thinking you have high accident count and a 2nd car fax ding.
and closer, you are too close, and further away, you are wasting inter-car
space...
to the OP, I would report the 2nd incident to the responsible parties insurance.
UPDATE 3/24/15
Porsche of Huntington has just selected Supreme Auto Collision (http://www.supremeautocollision.com/Services.html) after releasing a previous body shop and my car is the second from this dealer. Supreme now has 3 Car-o-Line benches and looks like they want to do business with Porsche but here is the thing:
After removing the bumper and disposable impact bar, there was a small dent in the frame, about the size of a quarter. When I got there to inspect, it was covered with bondo, despite my request not to begin repairs. The owner states that they had it on the rack and all the points checked out. I advised him that Porsche requires the frame to be replaced not repaired. He strongly feels there was not the kind of damage as in "So you think its just a bumper job, eh?".
I think there may be more issues if they pulled the engine and replaced it (having to go back to Porsche for the pull; back to the shop for the frame replace; back to Porsche for the engine install; back to the shop to complete the work.) What is the worst of 2 evils: Pulling the engine and hoping they put it back right or, buttoning it up with just the evidently damaged pieces replaced?
Is there a definitive Porsche line for such questions as to when the engine and frame must be replace? Who do I trust? (destroying the car is not an option)
Thanks_Steve
Thanks_Steve
Whatever it takes to get the car back to its original state.
No expense should be spared and it's certainly not the body shop owners call on what is right for your car.
If there was a dent in the frame, he should have stopped right there and contacted Porsche.
Sorry for your hassles, but these cars are so precise that I would go the long and painful way to ensure that it's done right. If that means the dealer has to yank the engine and flatbed the car to the body shop, then so be it.
Received 5,388 Likes
The body shop should be able to properly drop the motor.
Sent from my iPhone using Rennlist
Received 1,543 Likes
Not even sure Supreme is an Approved Porsche repair shop, so don't know why Huntington is having them do it. Sounds to me that he has no clue and just wants to get it done asap and collect $. Throw in your zip code to check out approved shops.
https://www.porschecollisioncenter.c...&submit.y=-108
Listen to Porsche nuts and Larry.
No authorized Porsche Collision Center Shop would:
Put bondo in a dent in the frame.
Remove the engine at the body shop (even a Porsche Authorized one)
The car needs to go to the dealer, have the engine removed, the car go back to the body shop and then back to the dealer.
FYI, the body shop that posted that thread "So You think" is one of only a few in Los Angeles.
If that shop didn't listen to you, proceeded to fill a dent in the sub frame with bondo and is arguing with you, get your car out of there ASAP.
Unfortunately, the Body Shop is considered the "expert professional" and the insurance company will jump all over a bondo-the-frame solution, if the Body Shop says it's OK to do it.
If you can get the Porsche Shop Foreman (or other Porsche Rep) to condemn your frame, then the Body Shop may fall in line and perform the frame replacement.
I think this is a slim chance, but might be worth a try.
If not, you need to find the highest rated Porsche Certified Shop and take your car there.
Be prepared for the 1st Body Shop to want to charge you for shop time and storage, while they had the car.
Pay it, plus towing, if need be, to get your car moved to a better shop.
I doubt the insurance company will support you on moving the car, but they should cover your costs in the end.
Hey guys, just wanted to thank you for the shout out regard our bumper post. I'll have to keep the post quick so let me only add that if you've done your research, it's generally a good idea to take the advice of the shop (again, assuming you've done your research). A successful shop doesn't need your business that bad to compromise their rep. Because this is what we do, we have WAY more expertise than we could ever convey.
Happy Rennlisting!
Happy Rennlisting!
Stevie, why didn't you take your car to Sam Zamir's shop to begin with??
Sam Zamir, your shop can do a motor remove and replace on a 991, right??
I've seen too many 'insurance approved' shops with tools little more sophisticated than a hammer and the results of their work. I've spent non-trivial time over the last 20 years finding and fixing issues caused by such shops. The crap I've seen done to Porsche's - from work done poorly to parts the insurance company paid for that were not replaced - leads to that generalization. I would never let a body shop chosen at random work on a car I cared about.
There are always exceptions to generalizations. This:
From the other thread:
At the Porsche Training center, we do this exact repair (and a similar job on the front and sides) on training cars (called white body cars). And we are encouraged to risk mistakes and mess up there (versus in the real world). We let the service department handle the mechanical portions (they have their own training), just as they leave these things to us.
So if this car ends up at a non-PACC, since they can't even get the parts, they will just patch the cosmetic and pretend they never saw this damage?
For any car for which one has an attachment - as opposed to a car that's going to get 'used up' - it's necessary to find shops that demonstrate the above commitment to quality.
