PSE Actuator Solenoid location '14 991S?
Anybody have a picture or diagram that shows the physical location in the engine bay of the PSE solenoid for the actuators on the exhaust system? I can't seem to locate it.... The one with the orange plug on the GT3's....
David
David
Received 5,388 Likes
Dave, go look at Renlister's Money journal on the 991 GT3 Forum. He has some recent photos that might help you. And send him a PM he might know.
I'll be following your thread. Good luck.
Thanks. I flipped through all 12 pages of the GT3 journal and all I saw was a lot of detailing photos and a few where he disconnected the vacuum lines from the valves on the front muffler. Nothing about the solenoid. I know there are two schools of thoughts on whether it is better to disconnect the hoses and plug them to keep the mufflers in sport mode or if you should unplug the solenoid. People have had issues and successes with both methods on their cars. I don't like the theory behind capping the hoses as I feel the valves will be applying vacuum to a dead end and eventually fail as a result. I am also contemplating adding a switch to active when I want. its a siple 12v signal.
jawell1, yes you will get a error for the cooling system if there is a fault in the vacuum loop anywhere as the actuators for the trans coolers are also tied in.
My new, fourth generation, valve came with a new electric connection and wiring adapter. Maybe they finally got it right this time?
Sorry to hijack this but seemed relevant to an issue I'm having.... With PSE on I've noticed a marked resonance in the cabin in lower revs (when the PSE 'booms'). I'm pretty sure it was not there as new and is a recent effect. With PSE off the car is silky smooth... So it would seem to be an acoustic resonance effect rather than a mechanical issue.....
Does this sound like a vacuum valve issue to anyone .... Anyone else have this issue? Thanks all in advance! Maybe PM me to avoid this thread veering away from the original post
Sorry to hijack this but seemed relevant to an issue I'm having.... With PSE on I've noticed a marked resonance in the cabin in lower revs (when the PSE 'booms'). I'm pretty sure it was not there as new and is a recent effect. With PSE off the car is silky smooth... So it would seem to be an acoustic resonance effect rather than a mechanical issue..... Does this sound like a vacuum valve issue to anyone .... Anyone else have this issue? Thanks all in advance! Maybe PM me to avoid this thread veering away from the original post
a bad valve won't do it, correct. The system doesn't know if the valve is actually physically opening or not. I was talking a vacuum leak. This throws a coolant system error. Another reason I think its better to disconnect the solenoid than cap the tubes.
