Sottozero feedback
Sottozero feedback
I'm going to be buying a set of winter wheels and tires for my C4. The dealer has 20 inch carerra s wheels with Sottozero tires for $5300 for set. I can't easily get the Michelin Alpin 4s, which I think I prefer.
I will be driving them mainly in cold Cincinnati conditions, rarely will be used if snow on roads, unless I get stuck at office in snow, etc.
What do you all think. Are the Sottozeros Series II ok or am I making a mistake not getting the Michelin alpin 4s?
Secondly, I have Sport PASM and worry that a 19 inch wheel option would make the car ride lower...my driveway is already a slight scrape. Would the 19 inch make the car ride lower?
I got a set of 19" sottozero tires for my winter wheel set and I really liked them. Very comfortable ride and performed well. I have 20" for the summer, but chose to go with 19" for winter to provide a little higher sidewall.
I too live in Cincy and pretty much put mine away for the winter.
My issue is not traction or is the car capable in the snow. Its not even how I drive the car or do I feel safe doing so. The issue is all the mini vans, SUV's and trucks with big tires and wide gap tread for winter traction which ends up spewing salt and grit and small rocks all over me while I drive behind them, even at a safe distance.
Trust me it sucks when all you hear is ding-ding-ding-CRACK-ding CRACK! It literally made me cringe last year and motivated me to just keep my 911 in the safe cozy comfort of my temperature controlled warehouse.
Buy a Jeep, lift it and put big tires on it. Never get stuck and have some winter fun just the same. That's what I did.
GREAT LOOKING JEEP!
I hear you. I didn't drive it last year, but having an all weather 911 is why I bought the C4. I just LOVE driving the car too much to put it away for the entire winter. Now, for the snows you have pictured, I'll drive my VW GTI or Honda Pilot.
But for the other 80% of just cold weather days, I wanna DRIVE!
Thanks. Were they the Sottozero Series II?
Also, do they look "punier" or dramatically smaller in a funny way?
You can see the effect on a tire calculator like this one: http://www.1010tires.com/Tools/Tire-Size-Calculator
Even though the wheels are 19" the sidewalls on the tires are thicker, so as far as I could tell the overall tire diameter is the same. I didn't notice any change in ride height.
Another option to consider: since you have to buy another set of wheels to do this anyway, take the opportunity to get a really nice set of wheels you've always wanted--BBS, HRE, etc. Then use those nice aftermarket wheels as your summer setup with some Michelin Super Sports, and get Sottozeros mounted on your original OEM wheels for the winter. You would maintain a 20" setup year round, so you wouldn't have to worry about sitting too low and scraping on driveways. To achieve the stock wheel/tire outer diameter with a 19" setup, you'd need to increase the sidewall height to a point where the handling might be less crisp and responsive compared to the 20" setup. Stick with 20" winter tires and this becomes less of an issue. Since this would mainly be dry winter driving, the typical snow traction recommendation of going narrower and smaller in diameter doesn't apply. Maintain the OEM sizing to keep sharp handling.
I currently have 20" Sottozeros on my OEM Carrera S wheels for winter and like them. They are described as being more of a performance/handling-oriented winter tire, with less absolute ice traction compared to Blizzaks, so that sounds perfect for your needs.
And, BTW, get your tires from TireRack rather than getting gouged by the dealer.
Let me get this straight- the OP will be driving this winter, but only on dry roads, unless maybe he misses a weather report and it snows while he's at work. For that one odd occasion, which could be easily handled without changing a thing, we got recommendations for everything from doubling down with a track setup to going Full Monty 4X4. Man I love RL!
Excellent point. Even if it's a dry winter, summer tires need to be swapped out for winter tires. The summer rubber compound becomes too hard below 45° or so, and the tires become slippery plastic rollers. Especially on a relatively high-powered sports car like the 991, winter tires should be used.
I have decided to get the 20 inch Carerra S wheels with the Pirelli Sottozeros. I think they will serve my needs well.
