Unusual clicking noise coming from the engine...
An interesting issue came up last night with the C2. After a 30 minute drive in stop-and-go traffic, a fairly loud clicking noise began emanating from the engine bay.
- It's timed with the engine - i.e., its pulses are faster at higher RPMs;
- It's quite a bit louder than the normal clattering while the engine is warming up (loud enough to hear in the cabin);
- It's now constant - whether the engine and environment are cold or warm;
- No Christmas lights on the dashboard;
- No perceptible loss of power;
I had some free time to take it to the dealer for inspection today. There's a theory that it could be an exhaust leak, however it was inconsistent throughout the RPM range...enough to create doubt. Regardless, despite being 100 cars behind, the service manager felt it was necessary to bring it into queue immediately.
I'll keep you posted on what the verdict is...
I've heard something similar from the 3.4L in my 981BS, and there have been a few other reports if you dig through the threads here (and on Planet 9 where Boxster/Cayman owners hang out). It is likely to be the high-pressure fuel pump for the direct injection system, going by most opinions.
It's usually barely audible if at all, but sometimes gets quite a bit louder. I could be anthropomorphizing my car, but it sure seems to get worse after extended periods of idling or stop/go/slow driving, and better after a good old-fashioned Italian tuneup.
I don't think it's a huge deal, if you're hearing the same noise I do. These cars talk back.
This could be the sound of your water pump about to fail.
You should have about 3 months before total failure, but you should visit your dealer and tell them you think it's the water pump. Trust me. You don't want this to fail while you're driving.
The beginning sound is clicking. You hear it more when your car is next to a wall or high curb and your driver's side window is down. If you noticed it all of a sudden, it's most likely your water pump.
Get it verified.
Get it verified.
When not driven for a longer period of time I get a clicking/ticking noise too, but that's only until things warm up and then it's gone. I was told temorarily not enough oil pressure in the valve lifters, due to flat engine design, nothing to worry about in my case.
Get it verified.
Get it verified.
Happened at speed, not a good thing.
So, don't leave me hanging... What happens when it fails while driving?
It does seem to go away as I'm driving though.
I always thought it was the lifters.
After owning my m156 c63 AMG for 3 years, I thought a car couldn't tick louder than that beast.
My c2s sounds like a sewing machine at WOT
Good thing I got PSE and Sport Chrono, when driving I can't hear anything but snap crackle pop!
Get it verified.
Get it verified.
Totally different engine, but I this happen with my 928. Fortunately, I was only about a mile from home. I was able to fill it and limp home.
Mi650.
Your beautiful car. !! But every time I see your pic in your signature I see that long reflection on the top of the fender above the fuel door and I think someone keyed your ride!
Received 5,388 Likes
The key is shut her down asap or run the risk of massive overheating, warping of expensive bits, etc. It doesn't usually grenade like the IMS bearing. My 993 was immune to this pesky item called a water pump...
