Engine Stumble on Roll Out
The 'stealth' type engine flutter is different... Not dangerous and always at modest speed in my experience. The pdk can momentarily stumble to find/get in gear from a stop in 'normal' mode due to combination of gliding & auto stop/start but you should never get this in sports mode .... Dealer visit needed. Good luck
I have a 2014 991S PDK. It's developed an issue that I likely need to just go to the dealer for, but wanted to ask if it was common.
Occasionally from a dead stop, when I apply the gas the RPMs rise and then the car stumbled as if on a manual car you either let the clutch out too fast or gave it too little gas. Of course I compensate by giving more throttle, then once the engine recovers it revs very quickly.
I can't really determine if it's a cold/hot thing. I've had it happen in normal and sport mode. It's happened when I'm trying to smoothly accelerate and when I've given ~1/2 throttle.
It's kinda dangerous. A couple of times I've pulled out with plenty of distance to cross a one way street by my house, but the car bogs, hangs for a second or two, THEN goes. Which when your car has moved into traffic, is not a fun thing to happen.
Is this a common issue?
My car has about 19K miles on it right now. I've had this problem just a couple of times until just recently, so I wasn't really worrying about it. But now it's misbehaving almost daily so it's becoming a concern. I'll wait a little while and try to document exactly when it happens, and then try again with my dealer.
DMoore
'13 991S
'13 Panamera GTS
Magnus357, what you describe has been reported by several others.
It is not a consistent issue.
I got sick of it and now always turn off PSM, which seems make the car drive better in just about every situation.
I found I also have to disable stability control, on my AMG, in order to get proper power delivery.
Just another example of how a computer struggles with perfotming a simple task, that is 2nd nature for a human.
I would suggest doing the same journey in sport to see if it makes a difference. This deactivates auto start/ stop and gliding which I don't think help the issue but that is an educated guess. At least if that stops the problem you have a bit more information to help the diagnosis. GL
To the OP, personally I never had that stumbling thing happen !
Just a suggestion, but if it is happening frequently, why not take short video to show the dealer. Do you think you could see it in a video - maybe the revs on the tach?
My '13 991S PDK has exactly the same problem. I just took it to the dealer last week. Their mechanic couldn't replicate the problem and sent me away without a fix. Mine does it just about every morning. I have 4 or 5 stop signs and a half dozen stoplights between my house and the freeway, and I'll get the same problem at least once or twice a morning.
DMoore
'13 991S
'13 Panamera GTS
DMoore
'13 991S
'13 Panamera GTS
I am starting to have this type of issue also. Mine is MY14 with 3800 miles and PDK. It has just started doing this and the car is going in Monday for something else but will bring to their attention. So far it is not very prevalent and I know they won't find it but I will make sure it is noted so when it gets more prominent they will already have record of it. This may be more of a motor hesitation but not sure since it has only done it a few times that I noticed.
I had this same kind of issue with my 201 Panamera and was one of the main reasons I sold it. It was so bad I had to plan for it each time I was at the light. The Dealer looked at it several times then said that is the way 2010 are but since 2011 not an issue.
It's as if the PDK is letting out too much clutch for the throttle position I give it. So the engine bogs. The computer recognizes the engine is not at the correct RPM and I believe takes over the throttle. That's why even though you give it more gas, you don't get immediate response as the computer is currently managing the throttle to prevent the engine from dying.
What you're describing is what's happening to me.
I like how your thinking, but it is not limited to the hold feature. Sorry if this is not your train of thought. It happens on the rare occasions when I have a chance to jump on it from a standing start. Did wonder if it could have to do with shifting energy to the front wheels on the C4S.
