Used Oil Analysis On 991
Old 04-15-2014, 08:58 AM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
Default Used Oil Analysis On 991
Here is the Blackstone UOA on my 2014 C2S PowerKit.
Nothing earth shattering. It's all as expected. I always like doing an early oil change about 1/2 way through the break-in process.
About 1,300 easy miles. All under 4,200 RPM. Mostly long drives. Varying the RPM's. No lugging.
We know these cars throw a lot of aluminum as the engine breaks in. I expect this to level off at about 20,000 miles. The Mobil 0W40 factory fill looks very normal, as expected, to me.......low range on Phosphorus, low range on Zinc, and the viscosities (210 and 100) are on the low end of the range (Mobil shears down a lot).
My car was refilled with Joe Gibbs DT40 5W40 (just about 7.5 quarts) and fitted with an L&N Engineering magnetic drain plug. My plan is to do another oil change and UOA at about 4,800 miles (mid summer) and again prior to winter storage (mid October) at about 8,300 miles. Based on those UOA's I'll decide if I am going to stay with the Joe Gibbs DT40 or switch over to Mobil 5W50. In prior Porsches, I've had great results with the 5W50 Mobil 1.
Old 04-15-2014, 09:25 AM
extanker
extanker's Avatar
a 2104 c2s ?????????????i'll say you do early oil changes
Old 04-15-2014, 09:32 AM
LexVan
LexVan's Avatar
Yes, I am ahead of my times. The typo is fixed. Thank you for pointing that out.
Old 04-15-2014, 11:04 AM
kosmo
kosmo's Avatar
looks good
Old 04-15-2014, 11:07 AM
LexVan
LexVan's Avatar
I hope others start doing UOAs on the 991 motor and post in this thread too.
Old 04-15-2014, 11:15 AM
lunarx
lunarx's Avatar
So many cars specify 0-40 now, do you think 0-40 is worse than 5-40 or 10-40, once the oil is up to temperature?
Old 04-15-2014, 11:18 AM
LexVan
LexVan's Avatar
Not going to debate or discuss in this post and turn this into a $hit storm oil thread. Sorry. I'd like to see this fill up over the coming years with UOA results. Thanks. I think this approach will better serve our Forum.
Prairiedawg (11-15-2022)
Old 04-15-2014, 01:02 PM
kosmo
kosmo's Avatar
Lexvan, good job for not taking the bait! (SLOW CLAP)
IrocMan (12-22-2020)
Old 04-15-2014, 01:09 PM
LexVan
LexVan's Avatar
Thanks! LOL. Besides, the actual UOA results will answer Lunarx's questions better as a result. With real data. Not some warm and fuzzy feelings.
Old 04-16-2014, 12:12 AM
chuck911
chuck911's Avatar
I'm having a hard time understanding what these numbers are supposed to mean absent any idea of where these elements are coming from. The biggest numbers by far - calcium, phosphorous, zinc, boron and molybdenum- are common components of the moly grease used in engine assembly. Barium is another (lesser) one. Probably most of the other stuff as well. Its hard finding this information on specific products and nobody (?) knows exactly what Porsche uses anyway. But I sink it is interesting that even in a brand new engine (supposedly undergoing massive "wearing in") that by far the most common stuff turning up is what was in the few dabs of grease used to put the thing together.
All the rest are trace elements. Where'd they come from?
I don't know about all of them, but tin, lead and copper are all commonly used in babbitt, the layers of soft expendable metals used in the journal bearings of the crank shaft and connecting rods. These are among the highest load and temperature parts in the engine. They are soft metals. In a new engine - if the need for "wearing-in" is real- they should wear a lot. Yet we see only these trace readings.
It would be interesting to hear from someone familiar with the composition of other parts such as cams, valves, piston rings, etc. to maybe gain some understanding of where these elements in UOA are coming from.
I have another one of these but for some reason RL doesn't want to upload. Whatever. Its the same pattern of grease and trace elements.
Old 04-16-2014, 12:22 AM
LexVan
LexVan's Avatar
Chuck, this has all been covered before. By Rennlisters "Kevin", Jake Raby, and Steve Weiner, just to name a few. And on Blackstone's web site.
Old 06-17-2014, 12:36 PM
LexVan
LexVan's Avatar
Stay tuned. I'll be updating this post next week with the UOA from yesterday's oil change (about 4,900 total miles.....about 3,600 on the Joe Gibbs DT40 5W40).
Old 06-17-2014, 12:45 PM
Mondrian
Mondrian's Avatar
What would be great is to post fresh oil UOA for reference - that would really light up the thread.
Old 06-17-2014, 12:50 PM
LexVan
LexVan's Avatar
You can get these from Blackstone and "Bob The Oil Guy" website. Even Jake Raby has posted some in the past. VOA's (virgin oil analysis) don't show much. No wear metals obviously. You mainly see the additive package (zinc and phos) and strong viscosity.
Or, run a VOA on your own, and post in this thread.
Old 06-17-2014, 03:50 PM
Ceepe
Ceepe's Avatar
Edit. Opps. Posted in the wrong thread. Sorry bout that.
Quick Reply: Used Oil Analysis On 991
