My 991 engine runs hotter than my 997.2
Old 04-15-2013, 09:02 AM
hockeyguy
hockeyguy's Avatar
Default My 991 engine runs hotter than my 997.2
One week into new ownership. Love my 991 C2S cab! I traded in my 997.2 C2S. Both cars with pdk.
I've noticed that my 991 engine, on regular driving (RPM below 4000 during break-in), usually gets to between 200-215 degrees. My 997.2 C2S would typically get to only 175-190 degrees in regular driving, unless I pushed it.
Is this typical? I'm thinking that the new intake on the 991 makes this engine run hotter...
Old 04-15-2013, 09:11 AM
chuckbdc
chuckbdc's Avatar
I believe the car is set up to run a bit hotter in "normal" mode to warm up faster for emissions and mpg purposes. If you put it in "sport" and keep driving, it will run cooler (eg it circulates fluids through the intercooler more- or something). Or maybe its getting ready for sportier driving?
Old 04-15-2013, 11:29 AM
TTCarrera
TTCarrera's Avatar
The 991 has an intercooler?
Old 04-15-2013, 12:33 PM
pfan
pfan's Avatar
I've also noticed the oil temp runs 20-30 deg. cooler in sport mode. Not sure how it's accomplished, but curious as to why it's not the default mode (cooler oil). Perhaps the higher oil temps (~225) are optimum, and more cooling is provided in sport mode in anticipation of higher rpm's.
Additionally, I've noticed that the electrical voltage will increase from ~13.5 to ~14.4 when sport mode is selected. Not sure if this is due to increased gen output or perhaps some type of load shedding.
Quick Reply: My 991 engine runs hotter than my 997.2
