Wheel spacers for C4S.
Old 02-27-2013, 08:32 PM
Mark GT3
Mark GT3's Avatar
Default Wheel spacers for C4S.
I saw the car for the first time today. It looks great. However even with the 5mm spacers fitted it seems like the front and rear wheels don't fill out the arches the way I would like them to. I think as much as another 10mm could be used front and rear which would mean a 15mm spacer. RSS makes spacers for the 997 in this size which are available in black with black bolts and it seems there should be no issues fitting these to a 991? Has anyone installed after market spacers yet on a 991 C4S? If so would size did you use front and rear? My car has PDCC + PASM. I'm not looking for nor suggesting there is a performance advantage in fitting the spacers, this is purely driven by aesthetics.
Old 02-28-2013, 12:48 AM
PcarFL
PcarFL's Avatar
out of context question: will the new turbo have the same exact dimensions (width) as the c4/c4s?
Old 02-28-2013, 01:07 AM
SSST
SSST's Avatar
I have 14's on all four corners of my 996 and that is about perfect. They also helped get rid of the under steer common to The 996 TT.
From your pictures, I'd say 10's would be just about right. 15s might take you into ricer territory.
Old 04-22-2013, 03:50 PM
RCMA991
RCMA991's Avatar
I just installed 7mm H&R with extended lug bolts. Really helps clean up the well area.
Where do I get Black lug bolts ?
Old 04-22-2013, 03:56 PM
yxc145
yxc145's Avatar
991 and 997 use the same spacer and bolt pattern. So you can use it on the two cars.
I bought a set of 7mm and a set of 14mm on Ebay with the extended wheel bolts for $155. they work fine.
Old 04-22-2013, 06:51 PM
RCMA991
RCMA991's Avatar
Thanks. I'll shop around knowing that I can order lugs that fit the 997
Quick Reply: Wheel spacers for C4S.
