991 Maintenance...shadetree mechanic
I was just wondering if any of you are going to do any of your own maintenance on your 991's, or just take it to the dealer for service?
I know there are pros and cons to doing your own maintenance, resale for example.
Perspective buyers like to see dealer maintenance logs, but doing it yourself does give one a sense of satisfaction, and you learn a lot about how things work.
I generally will cut Porsche's recommended oil change interval in half and do my own oil changes in between.
On my 2005 Boxster, so far I've changed the engine oil, done both front and rear brakes...pads, rotors and sensors, changed the manual transmission oil, changed the brake fluid, changed the air filter, topped up the power steering fluid, and will soon change the drive belt and spark plugs.
Unfortunately, Porsche's are not the easiest vehicles to work on.
I used to consider all of that as much a part of owning a Porsche as driving but now that the service intervals are so long I am out of practice!
