DIY: Visor Warning Stickers Removal
Old 06-09-2016, 01:25 PM
  #61
Archimedes
Archimedes's Avatar
Received 3,857 Likes on 1,901 Posts
Did this on all three cars last night. Easy peasy once I realized that the trick is to soak the rag and hold it against the entire sticker for a minute or so. Then it peels off in one sheet. The first one I just rubbed on the alcohol and it came off in pieces.
Old 06-22-2016, 08:22 PM
  #62
Por356c
Por356c's Avatar
I am a new 02 Boxster owner and I immediately wanted to remove those obnoxious air bag stickers off of my visors. I have a triple black Boxster and those yellowish stickers stuck out like a neon light. Thanks to this forum I went with isopropyl alcohol and in about 10 minutes I had one sticker removed. Easy peasy. No damage to the vinyl. Just keep resoaking your rag and keep rubbing the IA on the sticker gently and pretty soon they begin to dissolve. Clean up with a typical cleaner (401 or Fantastic) and then apply 303 or Armor-All and you'll love it.
David Preston
Michigan
Old 06-27-2016, 01:35 PM
  #63
carrerafanboy
carrerafanboy's Avatar
Thanks all for the great info regarding sticker removal!
I removed mine a few days ago from a 2013 C4S with vinyl sun visors, and took a few pictures of the process. I had great luck with the driver's side visor (no leftover residue and the vinyl beneath wasn't too faded), and good luck with the passenger side visor (some leftover residue which I'll try to get off soon).
I soaked a fresh microfiber cloth in 99% isopropyl alcohol, folded it over itself to make the footprint roughly the same size as the sticker, placed it on top of the visor, and bagged with a supermarket vegetable bag (perfect size!). Set a 5 minute timer to re-check that the towel was still moist, and then at 10 minutes I removed it and began to peel.
Take your time peeling! I can't stress that enough. I was able to get both off in one go by peeling very slowly. Once you get a corner up, slowly lift up the vertical side of the sticker, and once you've done that proceed to lift the entire thing. Let the sticker come off naturally with with very light pressure and it shouldn't tear. The sticker itself is very thin plastic, and is likely to tear if you force it to go any faster than it wants to.
I scrubbed off the remaining residue with isopropyl alcohol and a microfiber cloth, and then finished with a light coat of 3M 303 Aerospace Protectant.
Pictures:
Old 06-27-2016, 07:25 PM
  #64
Chris C.
Chris C.'s Avatar
I just did this procedure today with great results! You only need soak for 2-3 mins BTW, then peel off the label and follow-up with another rub down for any glue and "polish" the surface with microfiber. I used saran wrap on while it soaked. 5 min job per side total. Couldn't be happier!
Old 06-28-2016, 12:20 AM
  #65
RobC4sX51
RobC4sX51's Avatar
Did my 991 as well, no issue. Started to do my wife's CD, and after 3-4 minutes of alcohol pressed onto the visor, not one hint of it coming off. Try it another day as I had 3 other car projects on my car to do. Looks so much better now! Thanks for posting the details!
Old 06-28-2016, 12:36 AM
  #66
Porsche_nuts
Porsche_nuts's Avatar
Received 1,116 Likes on 666 Posts
Did mine too, but all of a sudden, the visors looked kinda naked. So, I decided to dress them up a little.
Old 06-28-2016, 12:46 AM
  #67
STG
STG's Avatar
Keep us posted on the DIY removal.
Old 06-28-2016, 05:57 AM
  #68
Porsche_nuts
Funny. Will keep the community posted.
Old 08-09-2016, 05:55 PM
  #69
oolor13
oolor13's Avatar
Just removed the stickers on my vinyl visors. Super easy, great tips here.
Old 08-09-2016, 08:00 PM
  #70
Bemo
Bemo's Avatar
I'm keeping mine because I don't have enough yellow!
Old 09-01-2017, 11:02 PM
  #71
shake1
shake1's Avatar
I'm trying to determine if the visors in my car are vinyl or leather. I have the "Natural Leather Interior in Espresso/Cognac." I'm assuming my visors are Vinyl unless explicitly stated as an option on the build sheet (which I don't have listed)?
Want to make sure I use the correct process for my visors without screwing anything up.
Old 09-03-2017, 12:06 AM
  #72
9ELOVIN
9ELOVIN's Avatar
Unless you ordered leather visors, your visors are likely vinyl. The alcohol that is advocated for use will damage leather visors. I just did mine and I have leather visors. I used the product called Goof Off. It works almost instantly and does not damage the letter.
Old 09-03-2017, 03:51 AM
  #73
porschemeister
porschemeister's Avatar
how about alcantara sunvisors? Use goof off instead of alcohol?
Old 09-03-2017, 10:03 AM
  #74
9ELOVIN
9ELOVIN's Avatar
I would though I have never actually done it. Therefore, I suggest that you start with a very small corner and see how the Goof Off reacts. I've never seen Goof Off damage anything so I believe you'll be fine.
Old 09-03-2017, 12:03 PM
  #75
Al.Fresco
Al.Fresco's Avatar
There is always this option....
http://www.ebay.com/itm/Porsche-Sun-...7/322700836213
Quick Reply: DIY: Visor Warning Stickers Removal
