White Porsche 991 Turbo S Gets BBi Autosport Stage 2 Power Package
Basic Sponsor
Attachment 1344394
To make this Porsche 991 Turbo S a faster car than it already is, we will be installing our BBi Autosport Stage 2 Power Package this week. The package includes of our Barcode Exhaust System, IPD Plenum & Y-Pipe, Cobb Tuning Access Port. Here are some detailed pictures of the build process and upgraded parts that we would like to share below.
BBi Autosport Stage 2 Power Package Includes:
Cobb Tuning Porsche 991 Turbo Accessport V3
Features
• Power Gains: Stage 1 increases power throughout the low and mid-range with maximum gains of around 60 whp are seen between 3000-4000 RPM. Low-end torque is increased by over 100 ft./lbs! Stage 2 gains 120 ft./lbs down low and nearly 100 hp. at peak.
• Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
• Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
• Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
• In Car Mount: The Accessport can be mounted in the vehicle to allow you to monitor the performance data.
• Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
• Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
• Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
• Full Uninstall: Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
BBi Porsche 991 Turbo Barcode Exhaust
• Produces more aggressive exhaust sound
• Reduces restriction to increase horsepower, torque, and improve throttle response
• 304 stainless steel aerospace tubing
• 3" diameter piping throughout system
• Meticulously TIG welded
• Brushed stainless finish
• Significant weight savings
• HJS OBD2 compliant 200 cell catalytic converters
• No CEL (Check Engine Light)
• Direct bolt on replacement
• Stylish design with laser etched BBi logo
• Optional high temperature black ceramic coatings available
• Handcrafted in the USA
• For off-road use only
IPD Porsche 991 Turbo /S Plenum
IPD 991 Turbo /S High Flow Y Pipe
IPD 991 Turbo Plenum & Y-Pipe Features:
• Increases horsepower, torque, and boost responsible optimizing air flow efficiency
• Designed with 3D Modeling & Computational Fluid Dynamics software
• Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
• High quality cast aluminum construction
• Direct fit OEM replacement
• Made in the USA
Features
• Made in the USA
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
We replaced the factory restrictive OEM plenum and y-pipe with the improved IPD system.
IPD Plenum & Throttle Body Installed Installed on Vehicle
OEM vs IPD Y-Pipe
IPD Plenum & Y-Pipe Package Mock Up & Dissected View
Installation of Exhaust and IPD Plenum & Y-Pipe Completed
- Jerry@BBiAutosport.com
OEM vs IPD Y-Pipe
Basic Sponsor
Basic Sponsor
