Sponsored by: Road Spy
Track prep?
Old 10-19-2016, 10:41 AM
  #46
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
The Turbo with PCCB uses Pagid pad shape 4927. It's currently available in RSC1 but also available in other compounds as special order. We're checking with Germany now on stock and I'll follow up.
http://www.paragon-products.com/Pagi...4927-pagid.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 10-19-2016, 12:06 PM
  #47
Pagid has stock in Germany of the 4927 in RS29, RSC3, RSL1 and RST1. If anyone needs these compounds let me know and we can include them on our next stocking order.
Old 10-19-2016, 01:14 PM
  #48
gmgracing
Basic Sponsor
gmgracing's Avatar
Originally Posted by Randyc151
The benefits for the TTS are minimal, and few aftermarket parts for 991 TTS suspension. The front rotors on the Turbos are so big that 19" wheels will not fit without a full brake swap first, so no slicks will fit the 20" wheels that I can find.
Fortunately you now have the Trofeo R tire option for the TT/S. We've had them on Jame's RS, as well as a few Turbo clients.
https://rennlist.com/forums/991-gt3-...t-finally.html
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
Old 10-19-2016, 02:12 PM
  #49
nolimits
nolimits's Avatar
Originally Posted by gmgracing
Fortunately you now have the Trofeo R tire option for the TT/S. We've had them on Jame's RS as well as a few Turbo clients.
I saw the rears have a Lambo designation and have spoken with Tirerack in the past about that. Have you guys experienced that tread pattern, compound or something is indeed different about the Lambo size we would use for rears that is the size we need. Do all four match and have same characteristics for us? Handling balance difference? Or are there some other sizes you are referring to besides Trofeo R in OEM that you use?
Old 10-19-2016, 02:22 PM
  #50
nolimits
nolimits's Avatar
Originally Posted by Karl911
I just had Champion Motorsports adjust my camber.
Front -1.9, Rear -2.3
also had them install upgraded turbos.
Dyno 618 whp 93 Oct. / 658 whp 100 Oct.
I'm jealous, decided to keep warranty and certified thru 2021. Nice numbers!
Old 10-19-2016, 03:49 PM
  #51
gmgracing
Basic Sponsor
gmgracing's Avatar
Nolimits - With the 991 Turbo fitment the treads are the same front to rear. The compound is also unchanged. The only difference would obviously be the tire size.
This 991.2 Turbo just ran them out at Thermal this last weekend.
Old 10-19-2016, 04:54 PM
  #52
Jean
Jean's Avatar
Randy, actually its quite the opposite I would think, starting with stiffer anti sway bars, Cup LCAs, rear toe links and subframe mounts, the difference will be substantial on the soft 991 TT on the race track.. throw in a clubsport coilover with camber plates as bonus.
Concerning the wheels, here is one option, monoblocks excellent quality. http://www.daxwheels.com/collectie/dax1040/
Use them with 19" Pirelli full slicks, or Trofeos, Hoosier R7 or most other semi slicks.
3-4 seconds faster per lap on a 1,5 mile track wouldn't be surprising with such a setup.
Old 10-19-2016, 05:58 PM
  #53
gmgracing
Basic Sponsor
gmgracing's Avatar
As Randy mentioned, the small problem with that idea is that 19"'s will not clear the PCCB's. That is why I was excited for the Trofeo fitment on the stock wheels.
Certainly agree that if heavily tracked, the Turbo would benefit from some suspension stiffening.
Old 10-19-2016, 06:06 PM
  #54
Jean
Jean's Avatar
These 19" wheels do clear PCCBs.
Good to know about the Trofeos in 20" though.
Old 10-20-2016, 03:20 AM
  #55
nolimits
nolimits's Avatar
Re Trofeo R. I see rear 305 versions for Mclaren and Lambo only. Which one specifically do you use/recommend for our 991 Turbo rears to go with the fronts ?
Old 10-28-2016, 03:43 PM
  #56
MLB991TTS
MLB991TTS's Avatar
Good luck on picking up the car!
In regards to track prep, here is a recent 991.1 TurboS we outfitted with safety equipment prior to the owner taking it out.
https://rennlist.com/forums/991-turb...omponents.html
There are plenty of other examples/ideas that I can email you links for. We have a healthy amount of track experience, if you have any questions then by all means shoot me a PM.
- Andrew Adams
a.adams@gmgracing.com
Hey thats my car, thanks Andrew you guys did a great job I love the new set up
Old 11-10-2016, 04:57 AM
  #57
Foxsasha
Foxsasha's Avatar
Just bought a 991.1 TurboS S and am planning to use it frequently on track. Pagid RSC1s are a given but I would appreciate some input with regards to brake fluid and tyres:
1: is it necessary to change brake lines to run a higher temp fluid?
2: it has been said that Michelin do not recommend the Cup 2s for the Turbo and that the Dunlop SportMaxx Race are the recommended performance tyre. Any thoughts? I don't want to go to Tofeos as I need to get reasonable mileage out of the tyres.
Any other recommendations for a road car that will be used on track? The track tyres will be mounted on a second set of forged rims and fitted specifically for track days. I don't want to overly compromise the cars on road sophistication so am not looking at going mad with geometry, buckets and the like, I just want the car to be capable of being driven hard on track.
Thanks in advance.
Old 11-10-2016, 07:56 AM
  #58
Randyc151
Randyc151's Avatar
1. Nope, the fluid I use is Castrol React SRF and it does not need anything else.
2. I have run the Cup2 tires for 3 years, and highly recommend them. (Including 50+ track days) If you have anything credible you can link to regarding Michelin not recommending them for the Turbo, please share that. I know somebody that does use Trofeo R and likes the grip, but not the tire life.
3. The car can accept a reasonable negative camber without needing any further hardware, so just have the shop set it to neg 1.8 front and neg 2.2 rear and you will notice a lot of added stability, and better tire life. This does not compromise street use at all.
Old 11-10-2016, 11:01 AM
  #59
Foxsasha
Foxsasha's Avatar
Just hearsay on the tyres, nothing from the horses mouth. Do you run the NO spec Cups?
Thanks for the information, very useful.
Old 11-10-2016, 11:05 AM
  #60
Randyc151
Randyc151's Avatar
Yes, I run the NO tires designed for the GT3. Love them, all 7 sets I've bought over the past 3 years!!
Quick Reply: Track prep?
