Tracking the Turbo
#32
Is "new" in this case just the N1 spec tire?? That designation is molded on the tire and probably easier to deal with than the date codes. The PZero's I've had so far on my '14 car have all been N0 spec. I see Tire Rack has N1's in our "stock" sizes now...maybe that's a better choice than the MPSS which is in turn better than the N0 spec PZero's??
#34
Here are the new PZero's https://www.tirerack.com/tires/tires...el=P+Zero+(PZ4)
#35
Received 1,543 Likes
#36
So what are the numbers for the standard 991.2 Turbo? Big improvement on the 2-S times over 991.1, and would assume a similar increase on the 991.2-non-S, albeit a bit below the S. Is the suspension of the S/non S the same? From what I can determine so far it seems that the only difference between S/non S is larger ceramic brakes and larger turbos that account for the 40+ hp. Easy to get reliable 40hp with quality aftermarket tune.
The other difference is the PDCC dynamic chassis control. S has it, non-S it is an available option. Had that on my 991CS and makes a big difference on chassis roll and dynamic weight management. Due to weight of the turbo, I have read this is essential for tracking it. It was great on the CS. When off the roll bars are soft and ride is compliant, when on they are full stiff and steering input to chassis response time shortens. Great for tight technical courses (Sebring, maybe not so much).
Also careful with the wheel options, the stock non-S wheels are a half in narrower than the CL or sport techno options. I would go with the 5 lug ST. Easier maintenance, more aftermarket options, easier to clean and as wide as the CL. Not sure about weight difference which would affect braking and acceleration.
All the little things add up especially when looking at Ring times as fractions of sections at each corner add up over so many corners to real seconds.
Carmen
#37
What tire pressures seem to work best on track?
#38
With some suspension mods and tires it is quite competitive.. An experienced driver on both cars will be in GT3 RS territory. Still too heavy though to be a serious track weapon. 991 Cup cars on slicks are 6-7 seconds ahead with similar drivers on a 3.6 mile track, wearing Pirelli Trofeos.
Add bigger turbos, a tune and exhaust and you can shave another 2 seconds probably. This is my personal experience, which might be different for others here.
Never mind those stickers
Depends on many factors, suspension settings, tire brand, track temps etc.. but ballpark 30-34 hot for most tires is good.
#39
Keep the hot psi just below 35 and you should be good.
To the original post, a little bit of trail braking goes a long way to eliminate any understeer issues, as well as setting front camber to -1.7 (rear -2.2), which is the max on the 991.2 TTS.
FWIW, the TTS with Cup2 tires and those camber settings will absolutely leave a well driven GT3 on track. I'm 100% sure of it.
#40
Concerning negative camber - do you notice any excess tire wear or other issues with this setup in daily use (not at the track)?
I suppose turn-in will be a little sharper as well.
Did you alter toe in/out also?
#41
I don't put a lot of miles on the car anyway, and that's fairly mild camber. If you do mostly DD, then I'd just take it to the shop and have it set up for track before you DE, then change it back later. It's going to cost a few hundo to do that, but might save some tire wear on the Cup2. I don't change toe, except if it needs adjustment as part of the balancing after the camber change.
#42
Getting Prepped
Can't wait, things getting installed now. Keeping street ride but sport mode will be much better. Black/black with OEM powder coated extra wheels and a couple sets of Trofeos, Pagids to go with the ceramics, widened front end, lots camber all around. The DSC for suspension control and improvement. A little sound to bring some life to things too. More when I get to sort it out.
#43
Received 1,150 Likes
Looks very similar to what I want to do. Please write more about what's in the "package" and your impressions.
#44
-Rennline mesh grille guards
-Pagid RSC1 pads
-AWE mirror wind deflectors
-Tarett : front camber plates, front lower control arms, axel spacer kit, shims, lower control arm spacers, rear long & medium upper control arms, boot ends.
-DSC V2 controller
-Sharkworks catback exhaust
-OEM wheels, powder coated, Trofeo Rs
#45
991 TTS, goal is to maintain street ride but improve track ride without harshness. Firmer cornering, less brake dive and acceleration squat, better transient response, flexibility to tune and change configuration. Starting camber will be around 2.4 & 2.8. Widen front end and improve stick all around with the R's too. Equal or improved braking, but with less ceramic rotor wear. Should show rear views to new RS’s with ease given same driver skill set. Will provide impressions and results once we get some dry weather up here, and any sorting completed. Results will vary depending on configuration and how much deflection you leave. Check with your local shop for more on various approaches. I spoke with a lot of mod shops and race teams to come up with this. Kudos to them coming after results.
-Pagid RSC1 pads
-Tarett : front camber plates, front lower control arm, axel spacer kit, shims, lower control arm spacers, rear long & medium upper control arms, boot ends.
-DSC V2 controller
-Pagid RSC1 pads
-DSC V2 controller
