PCM issues
PCM issues
I'm having some issues with the PCM in my 2015 TT and wondered if anyone else has experienced these issues.
1. PCM reboots randomly while driving
2. Map cannot load in the main PCM screen or in the small screen next to the tach
3. iPod connects about 50% of the time
I think the last issue is separate from the first two, which are new, while the iPod issue has existed ever since I got the car.
The software on the PCM was updated last summer.
The car is going in on Monday but any insight would be appreciated.
Received 1,542 Likes
PCM in the 981 was replaced under warranty before the end of year one. Techs told me that they replace a lot of PCMs. (Where "a lot" means what? I assume it's an infant mortality issue.)
Spastic reboots might be a power or ground issue. But inability to swap bits with the dash suggests something less simple. Good luck.
I suspect you are right on the mark and a new PCM is in my future. I think the maps don't load in the dash because the HD is toast in the PCM and so the dash can't load anything.
I hope it isn't more serious although a 991.2 with the new PCM and steering wheel has some attraction. I suspect it won't come to that.
I had a Panamera that kept rebooting. It needed a software update for the XM/Sirius. My TT VIN is calling for a software update. Tech said don't do it unless PCM is acting weird as they crash a lot then need new PCM. Service will take care of you. Worst case new PCM.
Will update when there is a diagnosis.
So the diagnosis is that the car needed a software update. I thought it got one last year but I'll be happy if this is all it needs. Hard to understand the timing but as long as it works. Picking it up later today.
I hope that's all it is for you and it solves the problems the experienced.
Since our cars were built with a few weeks of each other, when I come out of winter storage and I go in for an oil change, I will ask about this update. If they provide you a Porsche Service Bulletin number, please post it here.
So some bad news. Although they did do the software update (version 4.73 updated to 4.76) and told me that everything was working fine, I tried to go to the map as soon as they brought my car down and maps still don't load in the PCM or the dash. I think they just didn't check to see if they had solved the problem. My suspicion about the timing of these problems seems to have been correct. Looking like a hardware problem - my uneducated guess is a dead hard drive.
So I get the Camry loaner to drive until they figure this out. New PCM seems more likely now.
Given that you got a Toyota as a loaner I guessing it's Ira in Peabody?
I'm trying to work through the issues with them. You are correct that they need to contact PCNA. The reason I have a Camry is that I didn't schedule this ahead of time - the dealership (not the one mentioned) that I am at usually gives out Cayennes or Panameras as loaners. We'll see what they say today.
