Specs on 991 TT 5-lug Turbo wheels?
I have been unable to find specs on the TT wheels apart from size of the wheel - 8.5 and 11 x 20. Any more details posted anywhere (offset, weight, etc.)? Trying to figure out if my 19 inch BBS wheels and winter tires will fit on my TT or whether I should sell them before winter starts and be ready with another set for the TT. Thanks.
Ok - so I found in the back of the 911 Turbo brochure that the 5 lug Turbo wheels are 8.5 x 20 with a 51 offset in front and 11 x 20 with a 56 offset in the rear. Wheel gurus - my BBS winter wheels from my C2S are 8.5 x 19 with a 51 offset and 11x 19 with a 56 offset. So the offsets are the same wheel to wheel. Should I then expect them to fit the TT? I can't even get TireRack to guess. Any idea? Thanks.
You need to look at overall diameter with tires and it should be close to stock. The other thing to consider is will it clear the brakes. Be very carefull with the ceramic rotors.
Thanks. I have steel rotors. One of the reasons I think the wheels will fit. If I had ceramics, then the wheels and tires would already be listed for sale.
