I have tried the rev limiter on my RS (in manual)
#31
Hopefully this plot will make this a little clearer. This graphically shows the max available power in each gear as a function of vehicle speed. When the available power in the next gear exceeds the power in the current gear, then you should shift.
The 991 GT3 has a peak below redline, but despite that you see that the ideal shift points are at redline for 1st->2nd, 2nd->3rd, and 3rd->4th. But once you get to the 4th->5th shift (at 135 mph!) the gear ratio spacing becomes tight enough that you actually get some power benefit from shifting below redline. So the theoretically ideal shift points are:
1st->2nd: redline (9000 RPM)
2nd->3rd: redline (9000 RPM)
3rd->4th: redline (9000 RPM)
4th->5th: 8850 RPM (135 mph!)
5th->6th: 8750 RPM (160 mph!)
6th->7th: 8700 RPM (185 mph!)
I'd be happy to create a similar plot for the GT3 RS if someone has the Porsche-advertised power curve handy.
#32
Hopefully this plot I've made will make this a little clearer. This graphically shows the max available power in each gear as a function of vehicle speed. When the available power in the next gear exceeds the power in the current gear, then you should shift.
#33
Has anyone seen an official 991 GT3RS power curve from Porsche? I've found the official GT3 curve, but I can't find an official RS curve. I think it would be interesting to overlay the two vs. speed in each gear.
#34
#35
