Chris Smith Racing roll bar
Super happy with this system so wanted to post. I like how he has triangulated and uses additional mounting points. Its still bolt in but seems like it will be very strong. Sub belts bolts to a fixed brace, not bolted to seat rails and is bolted in 2 planes. Great powder coating, fit and finish. Anyone in the Road Atlanta area and looking for a harness solution should give CSR a shout.
I believe Cantrell and I know GMG bolt in the same manner. They use the existing lap anchor point. No new holes drilled. So a weld in is better yes, but this lets me use a Hans
It's kind off in between a harness bar and a roll bar. Like the old Porsche Tecquipment bars no longer sold.
A little extra roll over protection maybe, the real benefit is Hans usability with harnesses.
Maybe a bit much scaffolding for only using (easy) seat belt mounting points. ;-)
I'm not sure how but the front part is bolted to factory welded plates in the tub. I've posted before hoping for a Euro CS Rennlisters to post photos with the carpet up, but no luck yet.
Others bolt to the upright "wall" behind the seats.
The rear part bolts to the shock towers actually making the rear part of the tub stiffer. Even more so when connected to the front part making it a full cage.
I'm OK with just a harness bar if we can't get the real thing. I'm even OK to not use a anti-submarine strap. IMHO we sit way to upright with side straps super tight to ever go under. The anti-submarine strap just adds some comfort as you don't have to yank the side straps so tight. Hans usage for comfort and neck safety (if I keep shiney side up) is most important for me. Full Roll bar better, full cage better but roll over strength of a 911 is not bad.. Safety VS convenience....
