Cup style rear wing for the GT3
Former Vendor
No the RS wing doesn't produce more downforce. The RS wing just sits higher so you can't compare the two. We will make a version for the RS as well.
This wing has a similar profile to a cup wing and produces about 25% at 100mph.
Cost of the wing is $2160. It's a direct bolt on replacement for the stock wing.
It is available from 1.40m to 2m width. In the picture is a 1.45m blade. Depth is 30cm
Former Vendor
The RS wing is meant as a compromise between street efficiency and track performance. The RS wing produces less drag. The cup wing has more rake build into the wing. 25% at 100mph is the equivalent of around 250kg.
Former Vendor
Originally Posted by Drifting
Vague answers.
If you're looking for a more specific downforce increase, I'd go with a Crawford wing.
The Crawford wing has the same wing profile or at least fairly close. So why would it produce more "specific" downforce??
Wouldn't that increase on the rear upset the balance on the front?
