991 GT3, GT3RS, GT2RS and 911R 2012-2019
PDK failure at the track
Old 08-09-2015, 02:39 PM
rm21
rm21's Avatar
Default PDK failure at the track
I went to the track this morning with some friends who were in from Germany. Given the heat, I was only going to run for a few hours in the morning while the temps were still reasonable. On my first warmup lap, I got an error message saying there was a transmission problem, and I may not have reverse gear. Given it was a warmup lap, I hadn't pushed the car at all. The transmission was jumping two gears at a time, and when I tried to shift manually, it would only enter the odd-numbered gears. Needless to say, I was freaking out, and immediately starting calculating how long it was going to take to get a new transmission in the car. We pitted in and I shut the car off, hoping it would correct itself after a restart. Sure enough, it did. I did three 20-30 minute sessions after that in the morning, and the problem never resurfaced. I'll take it to the dealer this week to see what they can see in the logs. I've got 15 track days on the car, and 6,000 total miles. Has anyone else ever experienced this in their 991 GT3?
Old 08-09-2015, 02:58 PM
dsc999
dsc999's Avatar
I had the exact failure (@ AMP) and SEM outcome. Car came back to life after an hour or so. However, I flatbedded the car back to dealer. No issues could be found. Chalked up to s\w gremlins
Old 08-09-2015, 02:59 PM
dsc999
dsc999's Avatar
Should be "same" outcome
Old 08-09-2015, 06:25 PM
rm21
rm21's Avatar
Thanks. Good to know.
Old 08-09-2015, 07:15 PM
NSD991
NSD991's Avatar
My prior 991S PDK did the same thing ONCE. After restart it was fine. Dealer didn't find a problem.
Old 08-09-2015, 08:06 PM
NateOZ
NateOZ's Avatar
How old are your fluids? I had a bad shift on Thursday in my PDK Cayman (made a slight grinding sound vs a typical shift) - only happened once in the lap and didn't resurface. I had Tech support so pulled into the pits and they were able to see what it was a pressure fault and fluid temps were too high. My sessions are 40 minutes and it happened at minute 36 or so.
Going to change fluids every 2-3 days now.
Old 08-09-2015, 08:44 PM
Frank 993 C4S
Frank 993 C4S's Avatar
The real weakness with PDK is cooling under track conditions, not the fluid itself. Supplemental cooling is a must if you plan to track your PDK car frequently.
Old 08-09-2015, 08:46 PM
sgroer
sgroer's Avatar
Received 1,013 Likes on 280 Posts
Were you at road a or AMP? I was at amp today in the m4. The track was so hot. Really difficult. The m4 has mpss and they greased up quickly.
Glad you ran it afterwards with no issues. I would chalk it up to the heat and software and move on :-). Might be wise to pull the codes.
Old 08-09-2015, 09:02 PM
NateOZ
NateOZ's Avatar
Agree (and have a 3rd radiator/trans cooler on my car), my point is more your fluids will degrade much faster in a PDK car than a manual car. By the time you get to the dealer the temps and pressures are probably back to normal.
Old 08-09-2015, 09:04 PM
Frank 993 C4S
Good point!
Old 08-09-2015, 09:41 PM
Guest89
Guest89's Avatar
How would you compare the two? Are you a member?
Old 08-09-2015, 10:15 PM
rm21
rm21's Avatar
I was at AMP. Sorry I missed you. I went early to avoid the heat and left by noon. I can't imagine how hot it would have been in the afternoon. Cool suit required!
Old 08-09-2015, 10:20 PM
rm21
rm21's Avatar
I don't think the issue was due to heat or fluids. It was my first warmup lap of the day and the problem surfaced before I started pushing the car. I believe it was just a software glitch. Still, not a good feeling seeing your even numbered gears disappear!
Are you saying you are going to change coolant every 2-3 days? That seems excessive.
Old 08-09-2015, 10:24 PM
malmasri
malmasri's Avatar
it is a known issue with the PDK, PCNA in most cases is not allowing repairs, instead they replace it and want the failed one back to the factory.I have seen It happen to a friend and the mechanic described the problem before we had a chance to say what happened.
Old 08-09-2015, 10:27 PM
rm21
rm21's Avatar
AMP is great in terms of low car counts on the track, given the private membership, but it is no Road Atlanta. AMP is a shorter and narrow technical track - if driver counts go up it can get bunched up given the limited number of places to pass. Road Atlanta is longer, with higher speeds and you can pass almost anywhere on the track.
Quick Reply: PDK failure at the track
