991.2 GT3
#31
Porsche only option with these flat6 NA engines are to add KERS technology and brakes regenerative charging to boost 40 to 60 more HP out of it.
I think 100kg weight penalty will come with hybrid technology at the least.
#32
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
and that future release(RS) would have seen comfortably higher than 9k rpm (false)
Hanz Head of Engine R&D said 991 RS will be the biggerstep ever made in compare to its GT3 (false)
so whatever execs ( or marketing people ...)says future can always change and present
prove we dont have to listen (trust?) them
#36
Like you said, if PAG wants to keep a flat-6 NA setup in future GT cars, then they either have to make the cars out of plastic, or require that the car be driven only with 100 octane fuel.
#39
Maybe a run of about 2000 to 2500 cars per year may be enough to make it economically feasible. It seems that there were 2500 to 3000 Gt3s produced MY 2015. Don't know if that is a good indication of the marketplace. Also could use for a larger displacement engine for the FeFi. Really we do not have not enough data to make meaningful judgement.. You could be right. The Mezger however was produced in rather small numbers and that did not keep Porsche front manufacturing it as expensive as it was. Maybe VW will put the kibosh to that.
Obviously such engine could be the basis for homologation for future competition motors.
One thing is clear in my head is that the 991.2 GT3 will have a flat configuration as that is the brand.
Porsche Motorsport wanted to offer the Mezger/GT1 Block engine in the upcoming 996 GT3 street car on the heels of the 1998 Le Mans success, but they were unable to make a business case for it given production numbers of race cars and GT3s. Only when the M96 engine was deemed unsuitable for the 911 turbo - and the GT1 block used in its stead - were there sufficient economies of scale to use the GT1 in the road cars.
#44
One thing to consider here. Assuming the next GT3 is only a couple years out, they don't have much wiggle room without it trouncing the RS. 7:25 vs 7:20 on the ring is a tight margin, and it's hard to believe they'll let the next GT3 be any faster than the RS (maybe the same). Also, given they needed to go to 4.0L to get 500hp, I'm not sure how much more they can squeeze out of the 3.8.
#45
