Current owners - Squeaky Brakes?
Received 1,139 Likes
I had track pads on daily drivers (or rather daily-drove track cars) for the last 6 years, so have a lot of experience with getting rid of squeal. It's mostly about the pad fitting in the caliper. Material is secondary. If pad is loose or unstable a tiny bit, it will squeal. It can be a million of things that make some cars make noise and some be silent - dust/dirt between pad backing and caliper, broken clips, oxidation, not precisely correct pad shape (for aftermarket pads) etc. Usually, putting some ceramic or even metal-based goo between pad and any part of the caliper the pad touches should fix squeal in fixed most multi-piston calipers. Sliding calipers are tougher because the caliper itself can make noise.
A common attempted "fix" is a multi-layer shim behind the brake pad to try and provide a little isolation between the pistons and the pad back. This is OEM on STIs as well as an add-on fix for some squealing Audi brakes on their TT RS.
It's disappointing to hear the PCCB squeals though... I figured the PCCB was a way to get track-level brake performance without the noise!
Anybody know what level of pad compound Porsche uses on the OEM iron red brake setup? Is it truly a track-capable pad that doesn't need swapping for aftermarket for medium track use?
I found they squealled when they dusted up, say within 2-3 days of DD after a good wash. Then after 3000 miles of road driving (even some fast road) I took them to teh track and within a single session they were stinking. I thought Id bedded them in with some high speed runs on the AutoBahn and Autostrada but in reality I never braked hard there. In reality one lap of my local track coming down from 240kmph to 90kmph a few times at the end of the front straight did the job properly.
Now the brakes never squeal even when dusted up!
I've had squealing brakes on both my sports cars so far. One with steels and one ceramics. I just keep driving them hard, track or road, and the squeal does eventually go away. I don't bother getting such sounds checked at dealer. While the squeal is there, I actually like it, it adds a mean soundtrack to the already mean n/a engine sound. When the squeal is gone, I kind off miss it, but at least the n/a orchestra remains.
Pccbs are standard on 458s, yet they do squeal on them. People pay a lot for them. It is just a part and parcel of high performance brakes. After a hard drive pccbs also produce dust. It is just a different kind of dust from what the steels produce. Easier to wash or blow way from the rims.
The noise is going to be normal if we can call it that way, because they are in fact performance brakes and they squeal a bit, i really dont mine that noise it just remembers me that im in a sports car. About dust it just collects a bit in the holes of the rotors, with a metallic pin you can reach one by one and clean every single hole so your rotors can breath better under any situation. I do this every month or depending on the driving mud of those days.
