Ceramics?
#31
I'm nearing the lock in date for my GT3 and this PCCB debate is driving me crazy
So the consensus seems to be for heavy track use, then steel.
For street use, PCCB is fine.
I've also read in this thread and elsewhere here on rennlist that the verdict is still out on the newest PCCB's. Anyone care to comment further on this?
My situation is in between: 4-5 track days a years, but driving at 75% (I have a Mini Cooper that I can take to the limit on the track), along with a couple of open road races (but these don't stress the brakes at all). Lots of highway driving to get to these events.
So, do PCCB's make sense for me?
Thanks,
Deven
Thanks,
Deven
The emotional parts ---- same brakes as 918, look gorgeous with the wheels, no brake dust, won't see them everywhere, gt3 deserves lightest components, etc
#33
If I wasn't going to occasionally track the car, I would definitely go with PCCB's.
When I do track the car, I plan to stay comfortably within it's limits, so I'm thinking PCCB's will be okay.
Finally, there is the Racing Brake option of installing steel rotors in a PCCB car if I ever start tracking the car much harder.
Deven
Deven
#34
I know there is a debate about how much weight savings there actually is because of the larger rotors on the PCCBs, And I wish Porsche would clear that up. But assuming the 7-10 per corner is correct I believe (despite what anyone may say) that you may very well be able to tell the difference---on the road. I had a c5 corvette on which I temporarily put aftermarket wheels (also unsprung weight) weighing app. 8 more lbs. per corner----and there was a clear decline in the nimbleness of handling. Obviously the GT3 is a much different car, but just sayin.......
#35
Former Vendor
Stock PCCB:
Front: 14.8 lbs (410x36)
Rear: 13.3 lbs (390x32)
RB Iron Rotor Replacement (Proposed)
Front: 27.9 lbs (410x34)
Rear: 21.8 lbs (390x30)
Note both front and rear thickness are reduced by 2mm.
#36
#37
yes. worth noting, that is considerably more than the naysayers have indicated previously... I locked PCCB thinking the difference was more like half that number, which for me, on a GT3, is still worth it...
#38
Those quoted numbers are comparing steel from the same size, stock steel is a little smaller.
Still, the front PCCB is 14.8 and stock size is 390? So assuming similar thickness its around 21.8lbs on steel fronts, or about 7lbs off each wheel on the front. If you guess about the same on the rear you're talking closer to 30lbs difference.
#39
I get the lighter weight issue of pccb vs steel. Will it make you any faster on the street or track (remember this is not a race car)...I argue no.
#41
it's not all about lap times... of course, we have had this conversation before...
would you really argue that 30-40lbs of unsprung rotating mass is not something you will feel on the street in terms of ride comfort over uneven roads, handling in the twisties, etc.? we can argue about whether that is the weight savings or not... if it was 10-15lbs maybe you wouldn't even notice. but 30-40lbs? I have never tested that kind of brake weight difference back to back, and I doubt many have, so we are ALL speculating a bit... but I have driven my previous cars back to back with significantly lighter wheels after fitting them, with far less weight difference than 40lbs and the car felt more lively in terms of handling.... placebo, I know
#42
#43
I should be more clear.
PCCB...
No corrosive Brake Dust - Good
Better Braking performance under extreme sustained braking - Good
Lighter un-sprung weight - Good
Other than the brake dust issue, I don't see a real advantage given their cost for a street car that can be used very effectively on a track. The extreme sustained braking and un-sprung weight issue would apply more readily to a dedicated race car...Not your average DE track driver and especially not for the street poser. Alas they are an option and a great money maker for Porsche. Personally I think they are cool...$10k additional cool ? Not for me. YMMV.
PCCB...
#44
I don't think it's placebo at all. When I changed to the aftermarket wheels I'm not sure I even knew the heavier specs before hand. The car felt different and I went back and looked at the weight spec. Ditched em, back to stock, back to
#45
I just like yellow breaks.
Tired of looking at red calipers all the time.
