Laguna Seca -- sound, times, tires, alignment
This was different when the 997RS arrived... We wait and see, I cant see how a 991GT3 cant do a 1.30 on Hoosier like tires at 475HP and 3200lbs..
More importantly how will they do for 50 track days of hard track beating? Hopefully as well as a TT does 50 Launch controls :-)
Ugh, sorry, it was not my intention to have a pissing contest. I only wanted to point out that I find the numbers a little suspect if your intention is to really compare times. I have to imagine based on times at other tracks that someone could pretty easily do a 1:37 or less in the gt3 with the factory tires. Again, sorry, didn't mean to offend.
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,744 Likes
Fair point, though, that if you really want to compare the cars, they each need to be driven close enough to their limits. Same applies to the journalist comparisons where they're supposedly getting meaningful lap times, but meanwhile chatting away and no helmets.
I watched the TT lap earlier today by Pobst and its about as fast as a 997.2RS with Van Overbeek driving, the GT3 should be faster.. I can just wonder in amazement how fast my relic 964RSA is on Nitto's at 3150lbs+ with me in it and a 3.6L that puts out 265HP?? Stick a pro in my 964 on Hoosiers and they will match the times... Maybe they are getting so wide, there's no track left for this big new cars LOL.
Rough crowd.
Difficult question.
One other important point to consider is that track times also depend on the ambient conditions. The last time I was there (July 2014) conditions seemed to be less favorable, though I don't exactly know why. Times were about 1-2 seconds slower than the prior year (July 2013).
P.S. NASA has had no sound limit days each of the last two years. There's a set number allowed each year and they are spread out somewhat among different racing organizations.
Difficult question.
Here are a few links to lap times for various cars:
Mostly Randy Pobst: http://www.motortrend.com/features/laguna_lap/
Mostly amateurs (Cup listed here faster than GT1 cars in July 2014--probably not repeatable): http://www.trackhq.com/forums/f94/to...ap-times-2418/
SFR region of SCCA (GT2 lap record is a Cup): http://www.sfrscca.org/index.php?opt...dSubmit=Submit
I agree. 1:30 is not going to happen. Randy did that in a Viper TA on slicks. And Jesse is no slouch in the least with a 1:33.1. I think 7 cups are in the 1:27-1:28 range. A set of hoosiers is not going to get you in the 3 second delta range on a track like Laguna.
I don't think 7 cups are in the 27s and 28s except under extraordinary circumstances. Patrick Long, on a good day in a factory prepped 7 cup, maybe so. But, regular guys on a normal day, I don't think that's going to happen.
The SCCA GT2 record in a 7 cup, held by B. Faieta (a very fast driver) is 1:31.8. NASA ST1 record in a 7 Cup, held by an old fart, is 1:32.6.
P.S. 7 Cups have 400 HP. The Viper TA has 650. That's a huge deficit to make up. We can't go 5 seconds a lap faster than Randy Pobst with 650 HP.
Wordsmith
I think if we take the :33.1 of the RS 4.0 and say a nominal :35.x as the 991 Turbo S as the brackets, on Sport Cup 2's or perhaps the wordily named "Dunlop Sport Maxx Race," maybe we see the car in that bracket. With a Cup wing, maybe a half a second quicker, relative to that time. With Hoosiers, maybe as much as two full seconds which are evident when the 991 GT3 is in a four-wheel drift in turns 4, 5, 6 and 10, just begging for some chemistry twixt track and tire.
The :33.1 from the 4.0 was on a "stars aligned" day when track, tires and car setup all came together and some aggressive risks paid off with minimal losses evident in the data.
I don't see any joy in those risks to be circulating at :33's for anything more than a flying lap or time trial, but if the 991 GT3 can be set up (camber, ride height, aero) without taking out PASM and run all day in the :35's, I think that's a lot of fun to be had without being on the knife edge or asking the car to jump off the top of the corkscrew, etc.
Wordsmith
First, thanks for posting - useful info.
Also, makes me feel better - I remember when I posted that I did 1.39.9x after spending less than an hour in this car on that track and having driven LS only once before in a different car, people were giving me a bit of hard time on this forum (and it was a 90dB day, so I had a huge power-sapping, downforce-ruining metal bong attached to my exhaust, that ended up melting one of my rear reflectors). So I don't feel like complete slowpoke now (or at least not the only one).
No, 39's are respectable and I think when we spoke on that day I suggested you weren't going to find much more if you're lifting (maybe a half second cost there, but I'll need to dissect the data and see ... the car's getting up around 8000 rpm there and the upshift happens with just a brief second of higher speed just after the bridge before brakes and then you're even overcooking it for the Sport Cup's to hold the car through the dip at the apex at T6. It's quite a handful to maintain the weight and momentum to give ita chance up the hill. It really lacks torque to get up the hill. A 430 Spider was the same acceleration as the GT3 wide open up the hill into T7. Of course, the GT3 gained about 200 feet (!) under brakes ... : )
By the way, I was finding 32 psi on a warm to hot track was stable and well balanced with only -1.9 front camber. 991 GT3 alignment is going to take some more laps to work through the combinations to find something better (in terms of the combination of toe, camber and tire temps for peak apex G's.)
BTW, Randy Pobst did 1.39.7 in a stock M4 and 1.35.6 in Turbo S on Dunlop equivalents of MPSC2s.
2014 Porsche 911 Turbo Hot Lap! - 2014 Best Driver's Car Contender - YouTube
So I think there is a quite a bit more in the GT3 even in stock set up.
Wordsmith
That is the "correct" line, keeping the right away from the drain, but there's a new pothole there, just behind and to the right of the berm, so you have to commit. A good line off the top and the landing is a neat compression. A little too far right and the landing is an ugly belly flop, dead cat bounce and then a squirm as PASM says "what happened?!"
I was warned about that but never felt it :-)
Got way off in the first days, but eventually kept the 2 whells on :-)
I Musta been flyin over that pothole previous days, not so much committing, just ending up there in a controlled crash and got lucky.
PASM?
PASM?
I don't usually count regular dudes in cups (unless they turn laps close to pro times) because you can never tell how good the driver is. James Sofronas' brother ran a 1:32 I think in a gutted 996 GT3. Faieta certainly qualifies as a guy I'd usually count, but with IMSA cup there, you can get a good gauge of what the car can do in very skilled pro/semi pro/amateur drivers hands. In fact, Faieta was running with IMSA at one point. I think he was in the slower cups though (pre 2010) in the gold cup.
Here are the qualy results from 2011
http://www.imsatiming.com/results/20...Qualifying.pdf
