Sport Chrono Package incl. Porsche Track Precision App
#46
Just an example, I was not suggesting that people create tracks around LA streets.
It might prove useful for people without official tracks though, for things like AutoX.
#47
Just tried messing with it.. It appears the app only works at the track... It asks you to select a nearby track.. Wont let you do anything else.... FYI to connect to the app select the WIFI from the car which will be something like "My_Porsche_........." Then type in GTx (case sensitive) then your VIN # ie GTxWP0..............
#49
#51
Yea I get you can map your own track... In theory that should work but I'm a little confused why one would do that? So attempt to track your GT3 and beat your times on the streets with the unforeseen circumstances of passive/ignorant drivers... No thank you....
On the other hand I guess if you just wanted to shoot come video of your drive with speed etc that might make sense...
#52
where does this video show up? on the APP or on the PCM display?
The bottom part of your picture is the key. It's almost like an AIM smartycam video. Let's say you hook a gopro to record out of the windshield, how can you get the bottom portion of your picture to appear in the video.
QUOTE=provoke;11790848]Yea I get you can map your own track... In theory that should work but I'm a little confused why one would do that? So attempt to track your GT3 and beat your times on the streets with the unforeseen circumstances of passive/ignorant drivers... No thank you....
I linked up and on the vid preview it shows, rpm, speed, g-force but no movement at least at low speed like 3-4mph... I guess someone is just going to have to get to a track and test it out....
[/QUOTE]
[/QUOTE]
#53
App.. I doubt you can overlay that specific gui on a gopro...
#54
#55
No option to record.. Like I said we will have to wait till someone gets either close enough near a track or on one.. That was only a "preview" I guess for like setting you iPhone in your car to one of those RAM mounts probably...
#59
Would you be willing to give it a try?? There are a bunch of us with just another 2 weeks or so until option lock. Still debating dumping Sport Chrono or not.
#60
Supposedly you can create your own track, so there must be a way for you to create a custom track that it records as you drive or is interested in through the app in some way, and then that should let you activate recording and upload a video.
