NEW MOTOR / NEW VIDEO
#92
I have added couple of more videos breaking in the new engine around Vancouver country sides & back roads. See link below.... I have many more videos from the past couple of weeks, and I will try to post most of them this weekend. The plan is to get the car ready for track before month end. Mark
https://www.icloud.com/photostream/#A3JtdOXmJpo4Hi
#95
Great driving. Looks like you were passing everyone.
BTW, at 5:05 and 5:35 for instance, it looks like the brake lights on the silver GT3 were flashing under hard braking. Do you know what specifically triggers this? I think someone else asked about this somewhere but don't recall seeing an answer about whether the 991 has this. Looks like it does to me now, but I'd like to find out more about this. Thanks!
#99
I believe the "flashing lights" come on during "Hard" braking and the car thinks your emergency braking and is meant to warn the car behind.
mine does it too so should be standard on all 991 GT3's
welcome buddy
cheers
#100
True, but with a set of extra wheels. At least they won't be wasted on the street. It probably won't help much. They're going to wear fast anyway.
I enjoyed watching you drive. If I could add some help to your driving. I'd like to see you start to roll on the throttle at the apex. You have a habit of coasting too far past the apex. Trail brake to the apex, and then roll on the throttle right away. Much easier to do if you LF brake. The transition from brake to throttle is seamless.
#101
Does it happen live or is it only on the recording because of the LED's? I haven't had the opportunity to see one in person yet to test the theory
#102
True, but with a set of extra wheels. At least they won't be wasted on the street. It probably won't help much. They're going to wear fast anyway. I enjoyed watching you drive. If I could add some help to your driving. I'd like to see you start to roll on the throttle at the apex. You have a habit of coasting too far past the apex. Trail brake to the apex, and then roll on the throttle right away. Much easier to do if you LF brake. The transition from brake to throttle is seamless.
Thanks for the feedback. Will work on that as well as left foot braking.
#103
#104
Arth. Great vid. Good lines. You are getting faster and smoother in the 991 GT3. How many track events now and how long/many laps each session? How many street Kms and how are the first set of MPSC2 holding up? Have you done Geo changes yet?
#105
Each session is 30 minutes long . 3 sessions in total. Car has been flawless .
Total kilometres on track is around 1000km. The remaining 2500 was breaking in on street.
MPSC2 are holding up pretty well actually considering the temps. I will be switch gin to Trofeo R's once they're gone though
No Geo changes so far. All stock.
Hot I'm running 2.0 front and 2.2 rear.
Cheers
