UltraViolet 991 GT3 RS Track Prep. Matching Roll Bar & Center Section Exhaust
Basic Sponsor
Attachment 1344394
We would like to present this Ultraviolet Porsche 991 GT3 RS that our client delivered to us with ONLY 44 miles from Fresno. To turn her into a weekend track warrior, we installed our BBi Roll Bar & Harness Safety Package and our Center Section Exhaust. Here are some pictures of the build progress that we would like to share:
Vehicle Specifications
Engine
Interior Safety
- Jerry@BBiAutosport.com
Engine
- BBi StreetCup Center Section Exhaust with Optional Black Ceramic Coat
Interior Safety
- BBi StreetCup Roll Bar with Optional Reinforcement Gusset, Custom UltraViolet Paint & Rear Cross Brace
- BBi Sub-Belt Bracket
- Schroth GT3 HANS harnesses
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Can't wait to see this with the matching UV Roll cage...
Does anyone know why it has 44miles on it if brand new? Mine had 15kms or 9 miles when I picked it up from the dealer.
Basic Sponsor
Jono809, The owner had the car shipped down here to a clear bra shop. And then he flew down to transport the car from the clear bra shop to ours.
Basic Sponsor
First upgrade for this project will be installing our Safety Package which includes the bolt-in roll bar, Schroth Racing harnesses, and sub-belt brackets.
BBi StreetCup roll bar to match UltraViolet exterior. It is also customized with optional eyelet bolt provisions for clip-in harnesses, modified rear section to improved access to the rear compartment, and optional motorsports style reinforcement gussets.
Features
To achieve a perfect match with unique colors such as Ultra Violet, we have to use a custom mixed PPG paint instead of powdercoating
Schroth Racing Profi-II HANS Harness, Porsche GT3 Specific in Silver to Match Interior
Porsche GT3 Cup Cars come with Schroth belts direct from the factory. They are specific because of the lap belt attachment. They have a sewn-in bracket that fits perfectly on the factory mount. Standard belts require additional fabrication and a spacer to make them work. These are a bolt-in replacement which is much easier. The sub-straps have no adjusters to fit correctly in the vehicle, and the shoulder belts are shorter to reach the works cages with minimal excess.
BBi Sub-Belt Mount Porsche 991 GT3/ GT3RS / Cayman GT4
If you have the optional Sport Bucket seats and planning to install 6-point race harnesses, then you will need this bracket. Shown here as a pre-production example, this bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes "X" brace on front sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
- Shoulder: HANS Specific 2" tapered to 3" Shoulders
- Lap: Sewn-in B43A (GT3 Specific Hardware)
- Sub belts: LV11 with B14 Snap-in Bracket Wrapped-in
- Include hardware: 1 SG23 7/16" Eyebolt, 1 S3 Wavy Washer
- Available with Pull-Down lap belts only
Features
- Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
- Precision CNC laser cut and bent from one piece high carbon steel for superior strength
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- Attaches to seat assembly using factory mounting points with all hardware included
- Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
- Made in the USA
Basic Sponsor
Next, we will swap out the secondary center mufflers with our BBi Center Section Exhaust To reduce weight and deliver a more aggressive exhaust note.
BBi Center Section vs OEM
BBi 991 GT3/RS Center Section Exhaust with Optional Black Ceramic Coating
Made in the USA, the new exhaust is TIG welded out of brushed T304 stainless steel and features the main pipes merging in the middle to function as an x-pipe. For those who desire a slightly milder exhaust tune, this piece is a great alternative to our Cup-style Side Muffler Bypass Pipes. By retaining stock side mufflers and valves, the factory "sports button" feature is kept to conveniently switch back and forth between the aggressive "sport" mode during spirited driving sessions and the quieter, more civil "non-sport" mode for minimal noise on the highway.
Key Features
- Delivers deep aggressive exhaust sound
- Significant weight reduction
- Retains Sports Exhaust Button function
- TIG welded T304 brushed stainless steel construction
- Factory primary side mufflers & catalytic converters are all retained
- Direct bolt on replacement
- Fits all 997 & 991 GT3/GT3RS models
- 50 State 100% emissions legal
- Will not void warranty
- Optional black ceramic coat finish available
- Made in USA
Some beauty shots without in raw stainless without the ceramic coating to highlight the craftsmanship
Exhaust installed
Basic Sponsor
Basic Sponsor
Finished project after we gave it our stage 1 suspension setup.
Exhaust Sound Clip
Exhaust Sound Clip
Basic Sponsor
