Side muffler delete & throttle response
Hi guys,
I've just installed the FVD side muffler delete at my local Porsche dealer, pretty happy with the new found aggression.
It's been over 30 degrees celcius(86-100F)+ here in the past few days since I picked up the car but I feel like i've lost throttle response...I'm not sure if it's the weather or the lack of side mufflers that is causing this. Anyone have any opinions on this?
I've noticed it from 3-4k rpm in say 4th gear onwards, I remember the throttle used to feel sharper...am I going mad?
Might need to go to a third muffler delete instead.
Hi guys,
Throttle response, the throttle just feels a touch slower to react. I'll have to wait until the weather cools down a bit to work it out.
It's the heat or your head :-)
Most likely the heat.
Flaps the same as the exhaust valves? My car is currently in the shop and I asked them to keep them open all the time so they added some BB's to the line right at the valves so they're open all the time. Bad idea? Not too late to reverse.
Always loud is nicer but you loose a little TQ. On the 997's it was easy to plug in or plug out the cable that powers the flaps..
For now I've left them alone but the car is too quiet from idle to 3500 or so.
If you unplug, you make the 50lbs worth of side mufflers useless and might as well do side muffler delete. Should only be $1000 or so and easily reversible.
Always loud is nicer but you loose a little TQ. On the 997's it was easy to plug in or plug out the cable that powers the flaps.. For now I've left them alone but the car is too quiet from idle to 3500 or so. If you unplug, you make the 50lbs worth of side mufflers useless and might as well do side muffler delete. Should only be $1000 or so and easily reversible.
I installed these on my car and I like them so far. No loss of throttle response detected. Slight drone when lugging on side roads under 3k RPM but nothing my wife complains about. Sound is definitely better than stock.
The FVD side deletes are the best option for the money. $400 for the pair. Can't beat that for the weight savings.
Right on the road you don't mind a few TQ's and on track you're never below 4K RPM.
Dundon headers are awesome and the best of all worlds.
If you you don't need cats like here in FL then they make big power, sound awesome and with a stock final muffler you keep the flaps working and can use the button.
With just side muffler deletes all you do is take out side cans and put 2 pipes in. Optionally you can keep the flaps working if you keep stock mufflers and side delete pipes with the valves.
On my 997's I did FVD aftermarket center, no flaps and side muffler delete.
So always loud, but not louder then a typical center muffler from Sharky.
I went through 6 different exhaust configurations.... IN MY OPINION..... by far the best balance of sound quality, sound level(loudness) and power was;
long tubes, no cats, valved side bypass pipes and factory center. The same configuration Dundon uses. I would love to try Akra center if it wasn't so damn expensive.
