Silver Porsche 991 GT3 RS with HRE R101 19" Wheels & StreetCup Track Package
Basic Sponsor
Attachment 1344394
Silver Porsche 991 GT3 RS with HRE R101 19" Wheels and StreetCup Track Package
We just wanted to share this stunning Silver 991 GT3 RS that was delivered to our facility to get our full BBi StreetCup treatment. This upgrade package includes our full BBi Autosport monoball control arms, springs, exhaust, and lightweight 19" HRE R101 forged monoblock wheels to reduce unsprung weight. Here are some before & after pictures that we would like to share.
Upgrades
Engine
• BBi 991 GT3 Street Cup Exhaust Bypass
• Porsche Motorsport GT3 Cup Exhaust Tips
Suspension
• BBi Porsche 991 GT3 Street Cup Monoball Control Arm Package
• BBi Porsche 991 GT3 Street Cup Spring Package
• BBi StreetCup Competition Corner Balance & Alignment
Wheels
• HRE R101 Series R1 Forged Monoblock Wheels
- Jerry@BBiAutosport.com
Upgrades
Engine
Suspension
Wheels
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
For the first stage of upgrades, we will install our BBi StreetCup Track Suspension Package to improve the handling. This package upgrades the factory springs with an improved linear rate springs and replaces the factory arms and links with the our billet arms that uses spherical bearings.
BBi Autosport Porsche 991 GT3/RS Street Cup Suspension Package
Complete Package Includes:
Components of this Package:
Monoball Control Arm Kit
Springs Upgrade Kit
Tarrett Front and Rear Adjustable Sway Bar End Links
[/FONT]
• Simple bolt in replacement for the factory drop links
• Left & right hand threaded rodends allow for simple length adjustment to eliminate swaybar preload
• Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends
• Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
• High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
• Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
• Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
BBi 991 GT3 StreetCup Adjustable Thrust Arms
• Connects the Lower Control Arm to the subframe
• Provides precision caster adjustability
• Spacers included for setting stock or anti-squat and anti-dive configurations
• Eliminates factory rubber bushings for improved suspension feedbacks
BBi 991 GT3 StreetCup Adjustable Thrust Arm Bushings
• Provides two eccentric mounting points
• Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
• A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
Taking a look at the stock components that we will replace
Front Springs
Rear springs and upper control arms
Rear lower control arm inner flange with rubber bushings
- 2 Coilover Spring (Front)
- 2 Coilover Spring (Rear)
- 2 Coilover Helper Spring (Front)
- 2 Coilover Helper Spring (Rear)
- 2 Monoball Lower Trailing Arm
- 2 Monoball Upper Trailing Arm
- 2 Monoball Upper Wishbone
- 2 Monoball Front Bearing Flange
- 2 Monoball Rear Bearing Flange
- 2 Upper Spring Rest
- 2 Lower Spring Rest
- 2 Adjustable Sway Bar End Link Front
- 2 Adjustable Sway Bar End Link Rear
- 2 Adjustable Front Thrust Arms
- 2 Adjustable Front Thrust Arm Bushings
Springs Upgrade Kit
[/FONT]
Front Springs
Basic Sponsor
Looking good guys! Stop teasing and show us the pics on the ground!
SupremePOWER Inc
1562 Kimberly Ave - Fullerton CA 92831
Contact: sales@supremepower.com - Shop# (714)632-1951
World's Largest Retailer/Distributor of BBS Motorsport & Street Wheels from 2015-2023
Huge Inventory: BBS, Kline, Brembo, Soul, Recaro, KW, Akrapovic & 200+ brands. Installation available
** Retail & Wholesale ** Global Delivery ** We match/beat any authorized dealer's price **
SupremePower.com // SupremeForged.com // Follow SupremePower on IG
SupremePOWER Inc
Basic Sponsor
Front thrust arm, thrust arm bushings, and inner bearing flange
Front suspension components installed
Rear suspension components installed
Basic Sponsor
Wheels are the last part of the build!!!
After the supension and power upgrades are in, we installed our Safety Package which includes Bolt-in Roll Bar, Sub-Strap Mount, and Shroth 6 point harnesses to properly secure the driver and provide additional protection.
BBi Autosport GT4 Safety Package:
Schroth Racing 991 GT3 harness
BBi Autosport GT4 Sub-Strap Mount
Roll Bar Installation Process
Carpet Trimming
- BBi Autosport 991 GT3 Roll Bar Satin Black Finish
- BBi Autosport 991 GT3 / 981 GT4 Sub-Strap Mount
- Schroth Profi GT3 6 Point Harness
Carpet Trimming
Basic Sponsor
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
If you have the optional Sport Bucket seats and planning to install 6-point race harnesses, then you will need this bracket. Shown here as a pre-production example, this bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
BBi Autosport Porsche 991 GT3 StreetCup II Bolt-In Roll Bar
Features
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Basic Sponsor
To reduce 40 pounds of weight and deliver an aggressive exhaust note, we swapped out the bulky OEM side mufflers with our BBi StreetCup Exhaust Bypass pipes as the last stage of upgrades.
BBi Autosport Porsche 991 GT3 RS Side Exhaust Bypass
Key Features
- Delivers deep aggressive exhaust sound
- Significant weight reduction of 40 pounds
- 304 stainless steel aerospace tubing
- Meticulously TIG welded
- Brushed stainless finish
- Stainless hardware and clamps
- 100% emissions legal
- Will not void warranty
- Factory secondary mufflers and catalytic converters are all retained
- 50 state emission compliant
- Direct bolt on replacement
- Compatible with 991 GT3 and 991 GT3RS models
- Made in USA
Basic Sponsor
Sweet build...could you PM me a break down list of prices + hours of labour required?
Also, with the 19", do the BBS wheels clear PCCB rotors and do they cause any issues with the traction/stability control given that the front to rear rolling circumference ratio is slightly off?
I really want 19" but have PCCB...
