991 GT3, GT3RS, GT2RS and 911R 2012-2019
DIY 991 GT3 spark plug change
Old 02-19-2017, 03:52 PM
  #31
MileHigh911
MileHigh911's Avatar
Originally Posted by Drifting
Really wish someone would address my warranty question from 3 posts ago.
I have never heard that in order for the warranty to stay valid, an authorized dealer must do the service. You can do it in your own, at an Indy, or at the dealer. Up to you. Of course, maintain proof of maintenance.
Old 02-19-2017, 04:06 PM
  #32
bronson7
bronson7's Avatar
I love this idea as I just had to pay $1200 for my 12000 mile service.
My only question is warranty. I thought the 4 year warranty depends on you doing the recommended service at the recommended intervals via your Porsche dealer?
I'd hate to blow an engine on the track and not be compensated due to performing my own 12,000 mile service.
Are you specifically referring to on track vs non track? There was some discussion a few months back re track warranty was in question in the 15/16 MY's, regardless who did the service. Aside from that, I would say regular road going should not be jeopardized if you do your own.
Old 02-19-2017, 04:25 PM
  #33
alpine-al
alpine-al's Avatar
As far as I know, in the US, the dealer/manufacturer cannot deny a warranty claim because maintenance was done by the owner or an independent repair shop instead of by the dealer. That said, I do have some things done by the dealer like tire balancing, alignment, etc. And I'll probably bring the GT3 in for the 12,000 mile service minus the spark plugs.
Old 09-09-2017, 10:49 PM
  #34
moabslickrock
3rd Gear
moabslickrock's Avatar
Very helpful write-up. Changed plugs today on my 2015. Torx fittings were T30 not T27, not sure if '14 differs from '15. Was able to fit small torque wrench; torqued plugs to 17 ft. lb.
Old 08-13-2018, 02:00 PM
  #35
GrantG
GrantG's Avatar
Received 4,721 Likes on 2,691 Posts
Originally Posted by alpine-al
Sorry about that. Correct numbers:
Bosch # ZGR5NQE. Porsche # 99917015390.
I love the idea of saving money on the plugs. Do you think the Bosch ones are pre-gapped like the Porsche ones also? Do we know the gap spec?
Thanks!
EDIT - found the Bosch data and theirs are gapped to 1.0mm. I assume same as Porsche ones...
http://www.bosch-automotive-catalog....uct/0242145562
Also, I see that the Part Number for the 2018 GT3 is one higher 99917015391 - wonder if Bosch has a new cross reference? The Bosch data mentions both numbers at the bottom of the data sheet under "Comparisons"...
Suncoast sells the .2 GT3 version for $147 vs. $138 for the .1 GT3 versions
Old 11-05-2018, 12:11 PM
  #36
poison123
poison123's Avatar
How the hell do you get that Bilstein sensor off so I can pop the heatshield off on the left side of the car.
Old 11-05-2018, 01:47 PM
  #37
Palting
Palting's Avatar
Oh, man! Now I have to add another thread to my subscribed threads!
LOL. Thanks!!
Now, if only someone can post a DIY on changing the center bolts, hub and rear bearings for the 6K "circuit driving" maintenance, I'd be set!
Old 11-05-2018, 01:48 PM
  #38
poison123
poison123's Avatar
LOL the right side was super easy...but that F'ing Bilstein plug for the PASM does not want to move...I'm not sure what the trick is on it.
Perimeter (03-03-2020)
Old 11-05-2018, 01:53 PM
  #39
GrantG
GrantG's Avatar
Could you post a photo? .1 or .2?
Old 11-05-2018, 02:02 PM
  #40
poison123
poison123's Avatar
https://drive.google.com/open?id=0B9...J0NG01SHdkOFRz
Old 11-05-2018, 02:38 PM
  #41
neanicu
neanicu's Avatar
Get a small flat head screwdriver and place it in the small rectangular hole,with the tip of the screwdriver towards the back of the connector. Pry the little tab up very very gently : you will feel it move slightly. In the same time push the connector in(not out)...like you are trying to plug it in...then pull out.
Good luck!
Old 11-05-2018, 04:43 PM
  #42
poison123
poison123's Avatar
Good luck!
Thanks bud. All done, did a 5 mile circuit and no warning lights so I'm going with I didn't screw it up
Old 11-06-2018, 09:22 AM
  #43
991carreradriver
991carreradriver's Avatar
Originally Posted by GrantG
Great write-up! I'm sure nobody here would mess it up, but I just thought I'd mention that with Aluminum heads, you really don't want to cross-thread the plug. So be patient and make sure you have the threads aligned (sometimes helps to slowly reverse-rotate the plug until you feel the plug seat into the threads before tightening in the correct, clockwise, direction).
I changed out my plugs before this track season. Cross threading is highly unlikely if your advice is followed. It is really a simple change out. I am only sorry I didn't change out the coils at the same time.
Old 01-28-2019, 02:15 PM
  #44
GrantG
GrantG's Avatar
Just curious if anyone knows the changing interval for the coils. Is it advisable to do every time you do plugs or maybe every second or third plug change? Thanks!
Old 01-28-2019, 03:33 PM
  #45
robmypro
robmypro's Avatar
Received 1,772 Likes on 1,020 Posts
That is a good question, Grant. I want to know as well.
Quick Reply: DIY 991 GT3 spark plug change
