GT3 Tools and Gear
#31
The big Iwrin clamp is just a woodworking bar clamp. It has trigger action, which makes it easy to use. In our case, you just flip one end so that the clamping faces are opposite each other. Then you place the fixed end on the brake pedal and the other on the seat bottom, so that you can trigger the seat end in order to depress the brake pedal.
The other tool never locked in place. It always slipped. Worthless POS.
#33
Other stuff I have had on my list..
What do you guys think of these track mats?
http://www.rennline.com/Track-Mat-Dr...fo/TM30/BLACK/
http://www.rennline.com/Track-Mat-Pa...ductinfo/TM31/
There is also this fire extinguisher that's large enough for PCA:
http://www.rennline.com/Fire-Extingu...fo/FE09%2DH3R/
Also the reverse camera:
https://rennlist.com/forums/991-gt3/...l#post11860048
#34
I found the Michelin Care and Feeding Guide good in the past for dialing in setup. I've not found one for the MPSC2 vs the MPSC but I think this is helps gets things dialed in.
http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
#38
Oil Filter
Mayor
We need to find a source for oil filters besides the stealership. I have looked high and low for comparable filter with no luck. Here is a photo of the filter on my car. I plan to keep looking. There must be a cross reference filter.
Users/edwardjenkins/Desktop/IMG_1064.jpg
#40
Mayor
#41
I guess Mayor I hate paying 55.00 for a 5.00 oil filter. Porsche seams to have the manufacturer Mahle tied up other wise we would have some competition.
#43
Someone asked about a collapsible breaker bar to fit in the frunk. I use this one: Matco, PN 14ADR40T
https://rennlist.com/forums/997-gt2-...r-for-cls.html
#44
In case of puncture, is the car equipped for a wheel change ?
Assuming we manage to bring her to any garage to change the damage tyre (supposedly while on a trip in another country and no Porsche dealer around) ?
If not what shall we buy to be equipped for such an occurence ?
#45
