991 GT3, GT3RS, GT2RS and 911R 2012-2019
Orthojoe's track build journal
Old 11-23-2016, 02:06 AM
  #1756
orthojoe
orthojoe's Avatar
Originally Posted by MayorAdamWest
Be like me and consider an M2 or 718S. It's a challenge! I'm still holding out hope that the next GT4 will have a PDK. If not, a C8 vette with a DCT sounds pretty nice. Maybe a GT350R with a DCT. For the moment, though, very torn between an M2 and 718S. Not looking forward to upgrading front brakes on a brand new, 90k 718S. Feels more approachable on a 57k M2
Both M2 and 718S are good cars, IMO.
Drove a 350R at sonoma. Awesome engine. The best way I can describe driving it is 'awkward'. Bad seating position. Car sits too high. The car is very capable, but you will need to work 2-3 times as hard to pull off the times it is capable of doing. Compare to a late model Porsche where you just get in and go. Also consider that the 350R tires are gone after TWO track days.
Corvette GS has worse tire problems than the GT3. Wider, more expensive, and cup2 only.
Old 11-23-2016, 04:00 AM
  #1757
skxf430
skxf430's Avatar
Corvette GS should be able fit an 18" wheel and you can typically run a 315/335 combo. You can either run Toyo R888 or R888R, or even Nitto NT01's. I was able to get about 5 track days out the NT01's and R888's.
Old 11-23-2016, 10:40 AM
  #1758
orthojoe
orthojoe's Avatar
The new c7GS? If so, tell Ben. He was looking into it and concluded he was stuck with oem tires.
Old 11-23-2016, 11:32 AM
  #1759
bensf
bensf's Avatar
Did extensive research on the cars on MayorAdamWest's list as a potential relatively inexpensive backup track car. Narrowed it to GT350 and M2 but both have limitations and now rethinking the selection. The GT350 for what Joe has stated and the M2 because it has dinky calipers and very intrusive nannies. You'll have to track it with all electronics off which may or may not be a big deal to you. Otherwise the car is fantastic.
Regarding the Grand Sport. The Z07 package adds 15.5" and 15.3" calipers. I don't think there's any way 18's will fit.
Old 11-23-2016, 04:34 PM
  #1760
MileHigh911
MileHigh911's Avatar
RIght...don't need/want the ceramics in the z07 package for most track rats
Old 11-23-2016, 04:44 PM
  #1761
thebishman
thebishman's Avatar
Finspeed make 18"s that fit, barely, over the CCMs on the FE7 car. Many 19" wheels will fit nicely which opens up the tyre selection. Lots of extra choices of course on the non-Z07 optioned car as the calipers are smaller.
Personally I use a second set of OEM wheels with MPSSs for the street, and keep the original wheels/MPSC2s for the track. Last well IMHO.
Bish
Old 11-23-2016, 04:53 PM
  #1762
skxf430
skxf430's Avatar
Aren't those the same calipers and rotors on the Z06? If so, guys have been running 18" wheels from Finspeed, Forgeline and CCW. It is a tight fit but it works. And, running either NT01's and Toyos makes the tire proposition somewhat affordable compared with Sport Cup2's.
Old 11-23-2016, 05:42 PM
  #1763
bensf
bensf's Avatar
I agree about the ceramics but doesn't the Z07 package have different suspension tuning?
Bish
Excellent information.
Yes, they are the same.
Thanks guys, really great information here
Old 11-23-2016, 06:24 PM
  #1764
MileHigh911
There isn't great info online about what "unique suspension tuning" means with the z07 package on the GS. It lists, sport cup tires and ceramic brakes. All GS come with the magnetic suspension. So the only thing I can think of is perhaps it has multiple settings with the magnetic ride. If they changed spring rates , etc, then they would be bragging about it.
Old 11-23-2016, 06:30 PM
  #1765
MileHigh911
And maybe the performance data recorder comes std in z07? Either way, I wouldn't opt for it myself. Brembo steels with a better pad and fluid would work just fine.
Old 11-23-2016, 08:35 PM
  #1766
thebishman
thebishman's Avatar
The FE7 option has different MRC calibration; different spring settings; (firmer F & R); different bushings; the CCM brakes with larger calipers, and the MPSC2 tyres. Still rides very well on the street, even when lowered btw.
Bish
Old 11-23-2016, 08:37 PM
  #1767
thebishman
thebishman's Avatar
PDR comes standard with the 2LZ and 3LZ packages. Standard brakes are excellent, BUT the CCM front rotor can be found for around $1500 per on-line. So very different replacement costs than the PCCBs.
Bish
Old 11-24-2016, 02:24 AM
  #1768
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
stop messing around just buy a GT4 and be done with it.
oh, my is conveniently for sale with all the cool parts on it and new tranny
Old 02-16-2017, 12:52 PM
  #1769
mlkissel1
mlkissel1's Avatar
Hi All, Doing my first track event in my recently acquired 991 GT3. Everything stock, and putting new heat cycled MP Cup tires on. I am by no means an expert driver, and still very much learning the car. Much discussion on sway bar settings for track......soft front Med rear, middle front hard rear. Have not made it thought your now 118 pages of information, but any recommendations to start learning this car on the track? Got a couple auto crosses in the car before it got cold here on the east coast, and soft back and med front was nice for slow speeds and keeping the back in line......Thanks all for newbee GT3 guy
Old 02-16-2017, 12:54 PM
  #1770
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
^^ Don't worry about it for now.
A good starting point is both middle and see how you progress.
Quick Reply: Orthojoe's track build journal
