991 GT3, GT3RS, GT2RS and 911R 2012-2019
Another bad thermostat?
Old 01-03-2015, 11:37 PM
SanDiegoDavid
SanDiegoDavid's Avatar
Default Another bad thermostat?
Had the warning light reading fault coolant temp followed by the yellow engine fault warning light come on today. The cooling fan ran continuously, so seemed like another bad thermostat stuck in the "open" position.
I had a bad thermostat on the old engine AND the new engine. If it is the thermostat, this will be number 3. Getting a little old.
Took it in for this, have the brakes looked at and file the warranty claim on the wheel chips.
This is my fifth Porsche, I never had these issues on the others. Is this common for the GT3? Any body have more than one bad thermostat?
Old 01-03-2015, 11:39 PM
chizi
chizi's Avatar
Location: Dubai, United Arab Emirates, United Arab Emirates
Yup had mine replaced too. Let me know how you get on with the wheel chips as I have a lot.
Old 01-03-2015, 11:41 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,480 Likes on 2,269 Posts
on my 3.8 and 4.0 997, i had this issue, it could be coolant temp sensor, disk valve, thermostat or temp sender. code is P2181 and P3081
i know trakcar also had similar issues
Old 01-03-2015, 11:42 PM
silverrules
silverrules's Avatar
Strange. wild guess but maybe something else causing the TS to go bad?
Old 01-04-2015, 11:48 AM
GTGTGT
GTGTGT's Avatar
I also had to get the thermostat replaced after check engine light and different temperature readings.
Old 01-04-2015, 02:46 PM
nycjwi
nycjwi's Avatar
How many miles do most of you have before this problem starts or is it something that happens shortly after leaving the dealership.
thanks
Old 01-04-2015, 02:50 PM
ATXGT3
ATXGT3's Avatar
Can we get years on these cars too--all '15's (OP looks like a '14)?
Old 01-04-2015, 08:22 PM
SanDiegoDavid
Mine is a 2014. Build date 12-5-2013. Had the first thermostat replaced on the original engine with only 400 mile. Engine replaced and 2nd thermostat replaced in October with 2500 miles on new engine. I have 7,000 now with the new issues. Will see what the error codes are on Monday.
Old 01-04-2015, 09:44 PM
SamFromTX
SamFromTX's Avatar
Weird to have it happen more than once in a brief period. Hopefully an easy fix, for good this time.
Old 01-07-2015, 06:12 PM
SanDiegoDavid
My SA informed me I need another thermostat AND housing. The housing for some reason is deformed and may have impinged on the thermostat causing it to be stuck in the open position. The housing needs to come from Germany, so 5-7 days for the part to show up.
Anyone else have this happen?
Old 01-07-2015, 06:59 PM
BigT
BigT's Avatar
Do you know if the bad thermostat which you have replaced is the actual engine cooling thermostat or a separate one which may be in place between the transmission oil-to-water heat exchanger and it's water line. I had that problem multiple times on my 997.2 RS and for the last year there has been a service bulletin out on it. I know the engine is completely different but perhaps the ancillary parts are the same. My 997 RS threw the same codes Mooty references. Mine was finally fixed permanently (I believe) when the latest style thermostat with the new vacuum diaphragm was installed.
Good luck.
Old 01-07-2015, 07:07 PM
SanDiegoDavid
Originally Posted by BigT
Do you know if the bad thermostat which you have replaced is the actual engine cooling thermostat or a separate one which may be in place between the transmission oil-to-water heat exchanger and it's water line. I had that problem multiple times on my 997.2 RS and for the last year there has been a service bulletin out on it. I know the engine is completely different but perhaps the ancillary parts are the same. My 997 RS threw the same codes Mooty references. Mine was finally fixed permanently (I believe) when the latest style thermostat with the new vacuum diaphragm was installed. Good luck.
It's the water line thermostat, in fact the water line is one of the parts. Hopefully it will be fixed with replacing those other parts.
Thanks!
Old 01-07-2015, 07:56 PM
BigT
BigT's Avatar
Good luck, hope it is the last time to the dealer for this. I'll watch mine closely when I finally pick it up next week. BTW, love your graphic, was considering something similar on my GT Silver-should never show up at the same event since we are on opposite coasts if no objection.
Old 01-07-2015, 08:11 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,383 Likes on 719 Posts
Good to see they found the issue and hopefully finally will be resolved forever
Old 01-08-2015, 12:05 AM
SanDiegoDavid
BigT,
No objection at all, go for it. KI Studios here in San Diego can fix you up. Mine is Stripe Kit #8.
D
Quick Reply: Another bad thermostat?
