OT:911R
#1713
Yes. I got to spend two days with Patrick Long and one other Porsche driver (who I can't name because of NDA agreements). I got time in the car on the Weissach skid pad and also the test track -- which is a pretty scary track to drive, very technical with lots of walls that would be moved farther back if it was a commercially-used facility. But I'm happy to say I brought the car back intact, and I'm going to get to drive it again in April on a stage of the historic Tour de France Automobile hillclimb race that was originally won by a 1969 911R.
Here are my driving impressions.
Obviously, it has less downforce and narrower tires than the GT3 RS. They put a diffuser in back, but I'm not sure how functional a piece like that is in corners, where body roll compromises its function. I believe they had to make some changes to the underbody kit up front to keep front and rear axle numbers compatible. I believe there is also a different (and more 'lively') programming for the rear steering on this model -- although I haven't seen that mentioned in the official literature.
Compared to the early 911 I'm used to driving, it's a very sure-footed car. But compared to the GT3 RS, up at speed, it's a lot more lively and engaging. The differences from aero are only going to be a factor in faster corners. But the tire-size differences and (possibly) rear-steering-programming differences give it a nimbler feel even in medium-speed corners. It's something you can toss around more easily than the GT3 RS (although again, all things are relative -- by 2400-lb 1972 is another animal altogether).
I liked that it was a 6-speed and not a 7-speed manual gearbox. I believe the gearing is lower than other manual transmissions Porsche makes (although, again, that might be incorrect -- I don't see it in the official literature). There is nothing faster than the paddles in the GT3 RS. But for driving in any kind of street situation, it makes (for me, at least) a better tactile experience to be using my right hand to upshift and downshift. It auto-blips downshifts in sport mode, but you can defeat that if you want to go for the full-on old-school feel.
The weight difference between the 911R and the GT3 RS is something I'd be hard-pressed to say I felt. Both are light by contemporary standards (and also heavy, relative to the 911 I drive). But I'm very happy to see Porsche making a new model that's lighter, and I hope they make good on their talk about getting out of the horsepower arms race and finding ways to reduce the weight (and size, if all my dreams came true) of future models. Modern Porsches feel very light on the track, because of the sophistication of their suspension systems. But I'd be thrilled to see them become actually lighter. There's no substitute for reduced mass when you take a car through a corner.
So which car would I own if I had the money and an allocation? It's not easy to answer. Porsche makes it clear that it does not see the 911R as primarily a track car. I don't think the half-cage is even an option on it. And if I were going to the track with one of these cars as often as I do with my 1972 911, then the GT3 RS would be my choice. You are either faster or slower on a track, and the GT3 RS is phenomenally rewarding to drive in those conditions. The paddles just amaze you as you go up or down. Everything about the car is positive.
For recreational street driving and even trips out with your wife, the 911R would be the easy winner. It's just so much fun to drive. There's more personality to its 'tossability' and rowing through the gears on a canyon road is a fundamentally different experience than tapping paddles. And while I fully understand the value of a big wing in 80+-mph corners, it's a different experience when you pull into a restaurant, where people might (in some way) lump you with the type of drivers to bolt wings to their Civics. Having no tail looks cleaner. It shows off the lines of the car better. And my wife would probably agree to sit in it.
Along those lines, I would say that the 911R would absolutely make a viable daily driver. Granted, I drive a 1972 911 with a cage around town, so my comfort level is pretty broad. But it's comfortable, not too loud (there's an exhaust button for when you want the sound to echo off the mountains), and it hasn't been stripped out so much that it feels unsafe or flimsy. It's got all that going for it -- and then it will feel a little more nimble and driver-controllable (if that makes sense) than the GT3 RS would on ordinary roads. So again, if I was a guy who was going to go to the track once a year but drive around my favorite roads more often, the 911R would be a Porsche that would be more rewarding, for me, connecting the heritage of the old cars with the technology of the new ones.
#1715
Yes. I got to spend two days with Patrick Long and one other Porsche driver (who I can't name because of NDA agreements). I got time in the car on the Weissach skid pad and also the test track -- which is a pretty scary track to drive, very technical with lots of walls that would be moved farther back if it was a commercially-used facility. But I'm happy to say I brought the car back intact, and I'm going to get to drive it again in April on a stage of the historic Tour de France Automobile hillclimb race that was originally won by a 1969 911R. Here's are my driving impressions. Obviously, it has less downforce and narrower tires than the GT3 RS. They put a diffuser in back, but I'm not sure how functional a piece like that is in corners, where body roll compromises its function. I believe they had to make some changes to the underbody kit up front to keep front and rear axle numbers compatible. I believe there is also a different (and more 'lively') programming for the rear steering on this model -- although I haven't seen that mentioned in the official literature. Compared to the early 911 I'm used to driving, it's a very sure-footed car. But compared to the GT3 RS, up at speed, it's a lot more lively and engaging. The differences from aero are only going to be a factor in faster corners. But the tire-size differences and (possibly) rear-steering-programming differences give it a nimbler feel even in medium-speed corners. It's something you can toss around more easily than the GT3 RS (although again, all things are relative -- by 2400-lb 1972 is another animal altogether). I liked that it was a 6-speed and not a 7-speed manual gearbox. I believe the gearing is lower than other manual transmissions Porsche makes (although, again, that might be incorrect -- I don't see it in the official literature). There is nothing faster than the paddles in the GT3 RS. But for driving in any kind of street situation, it makes (for me, at least) a better tactile experience to be using my right hand to upshift and downshift. It auto-blips downshifts in sport mode, but you can defeat that if you want to go for the full-on old-school feel. The weight difference between the 911R and the GT3 RS is something I'd be hard-pressed to say I felt. Both are light by contemporary standards (and also heavy, relative to the 911 I drive). But I'm very happy to see Porsche making a new model that's lighter, and I hope they make good on their talk about getting out of the horsepower arms race and finding ways to reduce the weight (and size, if all my dreams came true) of future models. Modern Porsches feel very light on the track, because of the sophistication of their suspension systems. But I'd be thrilled to see them become actually lighter. There's no substitute for reduced mass when you take a car through a corner. So which car would I own if I had the money and an allocation? It's not easy to answer. Porsche makes it clear that it does not see the 911R as primarily a track car. I don't think the half-cage is even an option on it. And if I were going to the track with one of these cars as often as I do with my 1972 911, then the GT3 RS would be my choice. You are either faster or slower on a track, and the GT3 RS is phenomenally rewarding to drive in those conditions. The paddles just amaze you as you go up or down. Everything about the car is positive. For recreational street driving and even trips out with your wife, the 911R would be the easy winner. It's just so much fun to drive. There's more personality to its 'tossability' and rowing through the gears on a canyon road is a fundamentally different experience than tapping paddles. And while I fully understand the value of a big wing in 80+-mph corners, it's a different experience when you pull into a restaurant, where people might (in some way) lump you with the type of drivers to bolt wings to their Civics. Having no tail looks cleaner. It shows off the lines of the car better. And my wife would probably agree to sit in it. Along those lines, I would say that the 911R would absolutely make a viable daily driver. Granted, I drive a 1972 911 with a cage around town, so my comfort level is pretty broad. But it's comfortable, not too loud (there's an exhaust button for when you want the sound to echo off the mountains), and it hasn't been stripped out so much that it feels unsafe or flimsy. It's got all that going for it -- and then it will feel a little more nimble and driver-controllable (if that makes sense) than the GT3 RS would on ordinary roads. So again, if I was a guy who was going to go to the track once a year but drive around my favorite roads more often, the 911R would be a Porsche that would be more rewarding, for me, connecting the heritage of the old cars with the technology of the new ones.
Watch this video and all your questions about downforce and RWS programming will be answered :
#1718
#1719
Received 1,723 Likes
Did you happen to ask why they only want to sell them to 918 buyers?
#1721
That video sums up the tech stuff very well. And you might notice the red 'PORSCHE' text on that one -- different from the all-black version on the other car you see in photos. The one with the red letters is the one I drove.
There was a lot of talk about the 918 buyers program and the relative scarcity they're planning for it. Not everyone agrees, I think. I know that I would say they should make as many as they can sell. But as AP indicates at the end of the video, there may be more of this type of car in the future.
#1722
Platinum Dealership
The PPN configurator shows the standard colors as white and GT silver and it has a few more color options not on the PCNA site that allows you to opt for black, racing yellow or lava orange for $6,950.
#1723
#1725
At least here in Toronto, all 3 of the dealers in the area expect to only get enough cars to cover their 918 owners.
