Brake Disks
Old 06-14-2016, 06:47 AM
fnel1771
fnel1771's Avatar
Default Brake Disks
I am considering going with 350mm front discs on my 08 CS for obvious reasons, but primarily cooling.
Has anyone here put the 2005 Cayenne discs on. My mechanic has put ATE 350mm discs on GT3's without any problem and I am considering trying them.I realize that that the calipers need to be moved, any idea where I can purchase the kit?
Any other comments or suggestions would be much appreciated
Old 06-14-2016, 09:05 AM
extanker
extanker's Avatar
iirc some folks are adding brake cooling ducts from a [gt3?] too
Old 06-14-2016, 06:22 PM
DaveCarrera4
DaveCarrera4's Avatar
Yep, what I did, cost like $17 each IIRC.
Old 06-18-2016, 07:48 AM
BE455
BE455's Avatar
Vision Motorsports sells a kit that will work: 996 gt3 6 piston calipers, spacer / offset bolt to adapt to the Cayman upright. They sell with or without a set of AP 350mm rotors. I personally installed it with girodisc instead
Old 06-18-2016, 08:39 AM
fnel1771
fnel1771's Avatar
Thanks BE445
Old 06-30-2016, 11:36 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
340mm GiroDisc slotted, done deal.
Quick Reply: Brake Disks
