Cyl 4,5 and 6 wont work
Old 06-01-2015, 01:15 AM
Ernest1980
2nd Gear
Ernest1980's Avatar
Exclamation Cyl 4,5 and 6 wont work
hello guys…first time porsche owner bothering you guys for your advice….I will be brief and not too much bla bla bla….
I just repack the engine
Porsche cayman 2.7 engine.
brand new everything, coils spark plugs, ventilation valve, etc etc etc .
heads in good conditions restored by a real nice machine shop
valves seated very well and tested with vaccum.
I done the job…Im mechanic.
problem is that left side head its cold…not explosion on cyl 4 5 and 6
I check everything icluiding the lifters….lifters are ok.
What I suspect its the time,
Timming on pistons 4 5 and 6 I believe its not correct.
Just looking guys for some pictures or the repair manual to recheck this issue.
Thanks guys and have a nice ride….
Old 06-11-2015, 01:16 PM
Boiler Inspector
Boiler Inspector's Avatar
After setting the timing on cylinders 1-2-3, you must rotate the engine a full 360 degrees before setting the timing on 4-5-6.
Old 06-16-2015, 02:55 AM
Ernest1980
2nd Gear
Ernest1980's Avatar
Thanks Boiler…..but If piston 1 go to top of the block on TDC, why cylinder 4 makes same thing? I was measuring this with a long ratch extension and boths cyl 1 and 4 goes up at the samen time…unless piston 5 and 6 makes something different when you turn the crank 360 degrees…
Old 06-16-2015, 08:33 AM
Boiler Inspector
I don't know why. I just know that you have to rotate the engine a full turn. Good luck.
Quick Reply: Cyl 4,5 and 6 wont work
