FABSPEED MOTORSPORT | Boxster Spyder Performance Package
Basic Sponsor
Fabspeed Porsche Boxster Spyder Performance Package
In our High Performance Porsche 987.2 Boxster / Cayman Sport Headers that we've designed for the 2nd generation 987 we've straightened out the tubes as much as possible for better flow out of the ports. Our headers come with copper gaskets which are more durable than the stock stainless steel gaskets. They are composite gaskets that are included for a leak proof seal.
We've included an Indy Car Formula 1 High Velocity Merge Collector which then flows into a 200-Cell HJS Tri-metallic Race Cat. Fabspeed only uses HJS genuine catalytic converters to get maximum power and reliability. No check engine light will be thrown with the HJS 200-Cell cats.
The exhaust gasses flow from the HJS 200-Cell Cats into larger Mandrel-Bent tubes with a flexible bellows to absorb vibration and shock. The Flex Pipe is then connected with Formula 1 V-Band Clamps with a ball and socket joint which then flow into our Maxflo Performance Exhaust, which are the largest mufflers that we were able to fit under the vehicle while saving weight.
The Maxflo Exhaust has a crossover pipe to cancel out certain sounds and two 90 degree bends that connect the tips which have clamps underneath for fitment adjust-ability. You are able to adjust length, pitch, and you can also roll them in and roll them out.
Our Performance Package also includes a Porsche 987.2 Boxster / Cayman EVOMSit ECU Tune. This ECU Engine Tune improves horsepower, torque, and driving characteristics by reprogramming various sensor inputs and air/fuel ratio.
A BMC F1 Air Replacement Filter is also included in our Boxster Spyder Performance Package. The BMC Air Filter Replacement is washable and re-oilable and fits all Porsche 987.2 Boxster / Cayman vehicles (2009-2012).
(Also ask about upgrading the BMC F1 Air Filter to our Porsche 987.2 Boxster / Cayman V-Flow Air Intake System for a direct replacement for the factory air box that utilizes the OEM "ram air" fresh air ducts for lower intake temperatures and added power)
Here's a sound clip to get an idea of what it sounds like!
One of our customers, Rick, also came by and gave an explanation about his stock exhaust as well in a short video after we installed our Performance Package for him.
For more information or any Inquiries feel free to PM me or email me! anthony@fabspeed.com
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
