Warning light on my 987s
Ok so I woke up this morning to attend the first autocross of the season and upon starting the car a warning light came on. The warning light says failure indicator with the oil temp. It's not running hot at all in fact the needle is buried at 100 and won't rise. It was extremely cold this morning here is philly if that helps. Any help would be gladly appreciated. Thanks.
Can you get the oil level reading? In the oil temp/oil level sensors I've seen the oil temp and oil level sensors are in a tube but have separate wires. If the connector is bad this might affect both readings. If the thermister is bad or its wiring bad just the oil temp reading will be wrong.
The really cold morning temp might play some role but I'm not sure what. Many cars are subjected to extremely low temps and and do not generate an oil temp error so the cold temp is not the sole reason for the error. It might have contributed something though.
Probably too late now but I'd give the 1st autocross a miss and book the car in for this. You want a working oil temp sensor/sender.
