2010 987.2 glove box removal
Old 05-14-2016, 10:39 PM
cmcchesney
cmcchesney's Avatar
Default 2010 987.2 glove box removal
I am trying to remove my glove box. The cd tray/holder/storage unit is broken. I can see two holes underneath the unit but there aren't any screws or fasteners that i can see. Is there a way to remove this without taking out the glove box?? Thanks for any help.
Old 05-16-2016, 11:56 AM
Georound
Georound's Avatar
Default Glovebox
Probably not. There are only four torx screws (if I remember correctly) that hold the glove box in. The cd holder is probably held in by plastic tabs and pushed in from the front.
Old 05-19-2016, 12:45 PM
cmcchesney
cmcchesney's Avatar
I can see two of the screws above the glove box, where are the other two?? On the sides underneath ? I can't see anything obvious
Old 05-19-2016, 09:55 PM
Georound
Georound's Avatar
Default Screws
If I recall, up remove the cardboard type above the footwell. Then the screws should be evident. Along the front edge of the box, pointy end up.
Quick Reply: 2010 987.2 glove box removal
