Hood won't open battery dead Help please!!
Old 07-16-2012, 11:35 PM
Texbuckeye
Texbuckeye's Avatar
Default Hood won't open battery dead Help please!!
Hi guys, I usually hang out in the 928 Forum but today I need help with my 2007 Boxster S. Upon returning from vacation I found the battery completely dead. I cannot pop the hood to get to the battery to charge it. I tried what the manual says first. No luck, Then I tried a portable cigarette lighter charger-nope. I called Porsche and they sent out roadside assist. He put a portable charger on the fuse according to the manual with a spare battery -no. I looked in the wheel wells for manual release cables, no luck.
Any other suggestions?
Brad
Old 07-17-2012, 12:18 AM
acadian_dad
acadian_dad's Avatar
Same thing happened to me on my 997S. I used a portable 12V battery booster/inverter box. It has a 12V accessory socket and came with a cable to charge it from a 12V socket on a car (eg male - male).
So I briefly plugged this cable into the cigarette lighter socket - just long enough to pop the frunk latch (and get my key out of the ignition where it was stuck as well).
I had tried a wall-wart charger in the cig lighter without success but this worked. So see if you can get access to something similar.
Old 07-17-2012, 12:51 PM
Texbuckeye
Texbuckeye's Avatar
Thank you that worked!
Old 04-01-2013, 06:14 PM
ymc226
ymc226's Avatar
The exact same thing is happening to me. Which portable 12V battery booster did you use? I assume it has to have a cigarette lighter connection as you can't get to the battery to get the jumper cables that most boosters come with.
Old 04-01-2013, 08:56 PM
Kevin Rohrer
Kevin Rohrer's Avatar
Here is an exhaustive article on the problem.
https://sites.google.com/site/mikefo...rbatteryisdead
Old 04-02-2013, 05:45 PM
Texbuckeye
Texbuckeye's Avatar
Make sure you hold the button on the key fob down until it pops!
Old 04-02-2013, 11:08 PM
Schmidts Cat
Schmidts Cat's Avatar
I just used jumper cables to the fuse box... Worked
Quick Reply: Hood won't open battery dead Help please!!
