968 Forum 1992-1995
PPI Results - feedback requested
Old 03-15-2017, 10:53 PM
Speedvagen
Speedvagen's Avatar
Default PPI Results - feedback requested
So I am looking at a 1994 coupe, 6 speed, with 76,000 miles. Out of town car and just got back the ppi results. Love to get everyone's take on these findings:
- oil leak; noted oil pan?
- steering rack was moist but fluid level was fine
- ac compressor leaking behind clutch
- lower control arm bushings torn
- hydraulic lines - rear rubber lines old
- window washer inoperable
- small cracks in dash
Everything else came back okay except needing new tires and some dents, dings.
Are the above items scary enough to walk away or expensive to repair?
Old 03-15-2017, 11:12 PM
tony968
tony968's Avatar
How much is the asking price? Is it another $5999 car? How rare is it? What's the color? These items are more important to me than maintenance items.
Old 03-15-2017, 11:16 PM
Speedvagen
Speedvagen's Avatar
Silver with a black interior. $15k.
Old 03-16-2017, 12:09 AM
Boeing 717
Registered User
Boeing 717's Avatar
Will you do the maintenance work yourself?
Old 03-16-2017, 12:34 AM
Speedvagen
Speedvagen's Avatar
Probably not, maybe the window washer and dash replacement I would do myself.
Old 03-16-2017, 12:36 AM
szerszen23
szerszen23's Avatar
When you say everything else came out "okay", did they actually note the condition of all the other components or only brought up what they saw as not "okay". The reason I ask is because I was blindsided because I trusted the mechanic looked with a critical eye, which did not happen. Read about what I experienced on my website. http://www.project968.org/the-start-of-ownership/
If still possible, have them take pictures of the problem areas and general high resolution pictures of everything else. The items they listed are not exactly bad if you do the work yourself. For example, an AC compressor rebuild is not the end of the world (94 runs R-134a), if everything else in the system is in good shape. Does the AC work? What is the pressure in the system? What I am trying to say is it might be a good idea to ask overly detailed questions about each one of these issues to really understand what you are up against. Focus on the high dollar items such as engine, gearbox, and body/paint (or whatever you might consider high dollar)
Was a compression check done? Leak down? Recently I spoke with a 968 owner and he mentioned that it would be very beneficial to boroscope the cylinder walls to see if there is any scoring. Since the engine does not have any sleeves, scoring can end with an engine rebuild that would require sleeving.
Bottom line is there will be more issues than the PPI points out (unless you know and trust the shop really well).
Good luck!
Old 03-16-2017, 01:02 AM
Speedvagen
Speedvagen's Avatar
I love your website - great reading about your adventure with your purchase!
As for your question about okay, they noted areas as okay or with the issue.
No compression test done but that is something I will ask for. The mechanic didn't think it was needed but I did ask for one. He sent the report right at closing so I haven't had a chance to talk to him yet.
I will want a mechanic to do all of the repairs for the leaks.
May do some wrenching of my own down the road but the leaks and control arm would be high priority for me. Wondering how much $$ that would set me back.
Old 03-16-2017, 01:23 AM
boost feen
boost feen's Avatar
Oil pan removal and reseal is going to cost you $800 and there's some other while your in there's like rod bearings and oil pickup that are just cheap insurance on a 24 year old. The A-arms and bushings are as little as $500ish with rebuilt and alignment or $1,100 with new oem.
Bottom line is if the carfax and story on the car being clean check out, if they have all the documentation and records for car last say 10 years or more, and if the paint/body are in very good condition then a $15k 968 is right on the edge of needing to be in very good to great condition even in a desirable color combo It still should not need anything major. Lots of minors on a sub $20k Porsche 968 in this market is expected but nothing like major paintwork or a bottom end job, or gearbox rebuild should be expected. Just my take anyway and silver is a very good color for me so I would be a touch in awe and just want it too no matter what the cost....
Old 03-16-2017, 09:47 AM
RajDatta
RajDatta's Avatar
$5-7k to fully sort it. That would not include any dings or dents. Body work can take things to a complete different level. Low miles, so that is a plus. Silver is a very nice color on 968's.
Old 03-16-2017, 12:20 PM
autosea
autosea's Avatar
Ill chime in since I live in Seattle, and own at least six of the 944 based cars including a 1992 968. Everyone has an opinion . That we all know. Just having a PPI done is a good start but in the end if you still are not sure if you should walk away would raise questions to me if you are really ready to take the plunge on one of these cars.
Also not to be negitive but in my opinion having resealed the motors on so many of these cars I wonder how the oil pan is said to be leaking but yet the whole front of the motor is dry.
Old 03-16-2017, 12:28 PM
Speedvagen
Speedvagen's Avatar
Thanks for everyone chiming in! All great pieces of advice.
Autosea - I think we talked about your 968 (Ballard - Golden Gardens, left you a note).
Old 03-16-2017, 02:16 PM
Jay Wellwood
Jay Wellwood's Avatar
Reads more like a $10K car...
Old 03-16-2017, 02:28 PM
Speedvagen
Speedvagen's Avatar
Curious - what do you think the car is worth with all the issues sorted out?
Old 03-16-2017, 04:24 PM
thomasmryan
thomasmryan's Avatar
$15,001))lol
the rate of return on sorting is minimal. the rate of return on driving a car that you sorted...priceless.
Old 03-16-2017, 09:40 PM
Jay Wellwood
Cool
Originally Posted by thomasmryan
$15,001))lol
^ +968
Quick Reply: PPI Results - feedback requested
