Short shift/tight linkage?
Are there any good aftermarket kits for the 968 to tighten the linkage up both at the transaxle and at the lever as there is for the 944? I havent found any. Shortshift isnt necessary.
Please advise
Please advise
The easiest is just to buy a new OEM shift lever. Not very expensive as i recall. The kit includes a new bushing and 'C' clip so that takes all the slop out. Thats what i did. I haven't heard anywhere that the linkage at the back is nearly as much an issue.
EDIT: I doth teleth a fib. I sold the 6 speed and put in a turbo 5 speed so thats all 944 stuff.
Registered User
You can get slop from worn components both by the shifter and also by the linkage in the front and in the rear by the transmission. There is also a plastic cup that the shifter sits in that can wear out over time.
All these components being plastic have limited life before they start wearing out and you start to get slop.
It's just the metal piece that the existing handle and leather fits over. The result is exceptional though.
Registered User
Thanks but the rear linkage gets worn aswell. On the 944 there is nice aftermarket parts available with uniballs and bronze bushings/needle bearings etc so my hopes were there would be for the 968 aswell? So if not I just have to get new factory parts then but if someone has info on other solutions please advise.
Regards
Peder
Regards
Peder
Rainman
take a look here for some inspiration that should be applicable to 968.
https://rennlist.com/forums/924-931-...t-linkage.html
probably 85% of shifter slop is at the lever in the front, the back linkage stays fairly tight but will wear eventually.
Thanks Spencer!
Will look into those mods.
/Peder
/Peder
Peder,
The 968 uses a ball and cup style linkage at the rear which differs from the 944 design; Though, I am sure it is possible to wear out this type of linkage, I would first replace the side bushings at the front (2) 999.924.002.40;
Good luck!
Good luck!
Regards
Peder
Well nothing is certain in life but these are the cheapest culprit ($2 list?). These are designed to wear at the lever/linkage pivot were previous early 944 designs were metal on metal and could heavily wear the pin on the lever. If your bushings have worn through it is possible the lever would need replacement though I would certainly hope this is not the case.
My 115k 968 had a set of bushings that looked serviceable but were worn and caused excessive slop in the shifter/lever (side to side while in gear). Upon replacement of just those bushings there was a good/ great improvement.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
