Tips and tricks to install factory 968 Splitter?
I just got a splitter from Carnewal, with the euro being 1:1 to the dollar, I thought now would be the best time to get one. Shipped Friday and got it today! Fast!
Anyways, should I just remove my batwing, line up the holes and drill away?
What have others done in the past?
Also is this really a factory splitter? It is polyurethane, has some material/marker stamps and the part number is partially there with the rest scraped off, so makes me think it was done off a copied mold.
Does not really matter, just curious.
Yes with my factory splitter I removed all my tin clips on the bumper cover then simply held up the splitter with 3 jack stands and cardboard shims to put pressure up to simulate the exact location then got under car with a tiny screwdriver and scribed a nice mark through each hole to show where to drill. Then you still the splitter with a 1/4" bit and sandwich splitter in between the batwing/under spoiler and use longer screws to squeeze it all up to bumper cover. The maritime blue splitter makes the car just look faster....
968 front splitter installed / David Pagan Promotion dp951
Pretty Easy install ( no special tools ) done quite a few , I started making my own design for my wide body cars ( still tweaking the design ) .
2 jack stands placed on frame rails or A arms area so you have access to the belly pan area , I prefer to use larger washers for more support on my installs. Promotion dp 951
