968 Forum 1992-1995
RH Speedline style wheel sizes for the 968?
Old 12-21-2016, 11:04 PM
touareg
touareg's Avatar
Default RH Speedline style wheel sizes for the 968?
For those of you that have the RH Speedline style, 3 piece wheels, what are the offsets and sizes that you have?
These are the sizes the are available in.
Thanks!
Front
Size Offset Finish Bolt Pattern List Price
18 x 8.0 27 Silver w. Polished lip 5 x 130.00 $999.00
18 x 8.0 52 Silver w. Polished lip 5 x 130.00 $999.00
18 x 8.5 21 Silver w. Polished lip 5 x 130.00 $1,019.00
18 x 8.5 46 Silver w. Polished lip 5 x 130.00 $1,019.00
18 x 8.5 59 Silver w. Polished lip 5 x 130.00 $1,019.00
18 x 9.0 27 Silver w. Polished lip 5 x 130.00 $1,039.00
18 x 9.5 47 Silver w. Polished lip 5 x 130.00 $1,059.00
18 x 10.0 15 Silver w. Polished lip 5 x 130.00 $1,079.00
18 x 10.0 27 Silver w. Polished lip 5 x 130.00 $1,079.00
18 x 10.0 40 Silver w. Polished lip 5 x 130.00 $1,079.00
18 x 10.0 54 Silver w. Polished lip 5 x 130.00 $1,079.00
18 x 11.0 5 Silver w. Polished lip 5 x 130.00 $0.00
18 x 11.0 16 Silver w. Polished lip 5 x 130.00 $0.00
18 x 11.0 28 Silver w. Polished lip 5 x 130.00 $1,099.00
18 x 11.0 40 Silver w. Polished lip 5 x 130.00 $1,099.00
18 x 11.0 65 Silver w. Polished lip 5 x 130.00 $1,099.00
Wheel styles are displayed using size and bolt-pattern only. For accurate fitment including offsets and brake clearances, please check the individual wheel detail or contact your sales representative.
Old 12-22-2016, 08:02 AM
Jay Wellwood
Jay Wellwood's Avatar
In the words of Raj-
"High maintenance - like a Supermodel".
Old 12-22-2016, 09:57 AM
968turbos2
968turbos2's Avatar
I run
and 18 x 9.5 47 Silver w. Polished lip 5 x 130.00 $1,059.00 still with the PZero's that came on them. Running Big Reds on the front and 964 rear brakes.
Old 12-22-2016, 10:52 AM
touareg
touareg's Avatar
Thanks, got any side shots?
Old 12-22-2016, 10:53 AM
jeff968
jeff968's Avatar
But just like the supermodel, they look fantastic.
Old 12-22-2016, 11:41 AM
chudson
chudson's Avatar
These are the "real deal" Turbo 3.6 Speedlines but the look is the same
18 x 8 ET52
18 x 10 ET61
Old 12-22-2016, 11:54 AM
touareg
touareg's Avatar
Thanks, wanted to see how well they fill out with offsets and sizes, I like my stance, but the P.O. did spacers, going to remove that setup. Really need to get that B pillar repainted.
Old 12-22-2016, 11:56 AM
touareg
touareg's Avatar
Yes, I keep going back to this style! Hard part is making sure you get the size you want, before dropping the 4k.
Old 12-22-2016, 01:09 PM
chudson
chudson's Avatar
I see that one of your choices for front is 18 x 8.5 ET46. I run an 18 x 8.5 47 on my silver car and the fit is great.
It appears that your only "close" 10 inch choice for rear is 18 x 10 ET 54. My silver car runs an 18 x 10 ET 62 on the rear. So the RH will be 8 mm closer to the fender than silver car setup and I don't suspect that will be a problem if your tire width is within reason and some negative camber exist. Perhaps someone with that RH wheel size can comment?
Old 12-22-2016, 05:46 PM
Boeing 717
Registered User
Boeing 717's Avatar
What size spacers and why do you want to get rid of that setup?
Old 12-22-2016, 06:01 PM
touareg
touareg's Avatar
I like the height, those wheels are knock offs, and no matter what I keep going back to the Speedline style of the Turbo S.
I have CS Springs on the front and back is indexed to match. So the height is nice, have not scraped yet, always did on my 951, so go figure. No wheel rub.
Wheels are stock 17 inch offset and sizes for a 968.
I don't recall the spacer sizes.
Old 12-24-2016, 07:15 PM
PorscheG96
PorscheG96's Avatar
The best 'safe' setup from that list:
And for a more aggressive setup:
[camber, not too tall of tire]
[5-10mm spacer, maybe 2.5" springs]
[10mm spacer, some camber, secure e-brake cable inward]
Old 12-25-2016, 07:32 PM
touareg
touareg's Avatar
Thanks, I assume by safe you mean minimal chance of having to roll fenders?
Quick Reply: RH Speedline style wheel sizes for the 968?
