airco delete
10-13-2015, 03:09 PM
airco delete
I want te delete my complete airco system from the 968, anybody a manual for that?
What part do i need to reinstall except from the unit in the dash?
10-13-2015, 04:37 PM
You will need to run an AC delete bracket, shorter accessory belt. Removed AC compressor, hardliners to firewall. That should get you close.
10-13-2015, 04:40 PM
And what about the 944 573 020 04 heater unit, can i leave that or do i need the 944 573 020 03 unit?
10-13-2015, 08:15 PM
I would leave the rest as is. Not worth the extra work or aggravation. Also, remove the AC condenser from front as well as reliever dryer.
10-14-2015, 02:52 PM
Ok, but is the heater working as usual with the other unit in the dash?
10-14-2015, 07:18 PM
Yes, your heater should not be affected from removing any of this.
10-15-2015, 03:33 PM
I will soon start with deletion of full airco system. Keep the forum posted.
10-15-2015, 10:05 PM
Thanks, would be nice to have this info!
10-21-2015, 04:18 PM
I replaced the airco unit with the original cs unit, everything works fine. Even with the airco parts inplace. Airco system is already empty.
Next job is te remove the airco parts from the engine bay.
I will leave the double fan unit in place.
10-24-2015, 06:07 PM
Do you remove the airco because of malfunction or to get a more CS like specs?
10-26-2015, 05:49 PM
It's all about more CS like specs.
The system is fine, but never used it, only regulary maintenance.
